Question about Refrigerators
Help hooking the water line up to a RCA NO-FROST MSX22GR21.7 cu. ft. Refridgerator -Freezer
  • 52 Answers
You must have water connection behind refrigerator. If you have water connection at wall, water hookups to refrigerators are 1/4 ,you can use copper w compression fittings to hookup. If not familiar with, might need to call plumber or ref tech
Posted on Apr 02, 2015
SOURCE: WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
Possibly freezer drain blocked causing ice build-up behind back freezer wall. This internal wall should be accessible by removing screws.Check fan motor in that area is working and also check that all door seals have no cracks or tears. This can cause ice build-up and motor to run longer than normally. benham's suggestion another possibility.Naturally have power off when dismantling anything.
Posted on Jan 11, 2008
docjohn174
  • 943 Answers
SOURCE: Frost build up in freezer/ very little cold air is blowing down to the bottom
HI thanks for your question. look to see if you can hear the fan motor running. if it is check for frost build up. if frost build up. its not going into the defrost cycle. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
  • 19 Answers
SOURCE: We have an electrolux 26.0 cu.ft. side by side for
i had the same thing with my Refrig/Freeze and the repair guy said that most times its a leak around the door seal. Take a piece of paper and put it between the door seal and where it touchs the freezer close the door see if the paper pulls out easly, if it does then you have and air leak, repeat it all the way around the door. Check the bottom side carefully. One other thing check the tempeture in the freezer it only needs to be between 0 and -5. Too cold will also cause air to be pulled through the seals.
Posted on Jul 26, 2009
Sea Breeze
  • 4654 Answers
SOURCE: TFX25PR TFT25 PR GE Profile 25.2 cu
Here are som links that will be helpful. I believe ice is blocking the defros condensate dran behind the freezer back wall of the freezer compartment.
Here are some helpful links.
http://appliancejunk.com/forums/index.php?topic=22.0 and http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/ Pour a warm solution down the drain with Clorox and I think that will help too. Hope this helps. Thanks, Sea Breeze
Posted on Jul 28, 2009
  • 363 Answers
SOURCE: refrigerator wont stay cold.Freezer works fine,no frost buildup
i replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Posted on Jul 30, 2009
Hello, actually my Maytag refrigerator is 22 cu ft. bottom -mount freezer. I'm pretty sure my freezer is the frost less kind but it has started getting frost and almost snow in it. I was just wondering...
Hello
Any freezer will accumulate frost on walls etc, eventually.Mostly in the summer when there's more moist air and door openings. The fan is supposed draw all moisture to the evaporator coils so you won[t get the frost , So if it is excessive check to make sure refridgerator compartment is keeping cold.If it seems warm to you,you probably have defrost issues.
If ok ,then check door gaskets for air leaks ,(excess moist air gets in).Or excess food ,especially at bottom might block some air flow.
regards
Jul 28, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Freezer is growing frost nd refridgerator not cold
There might be a problem with the thermostat and You can not fix this problem yourself So, it is better to call a Freezer Repair Expert near you as he can better help you.
Mar 11, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refridgerator side-by side dripping water drips to floor and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 06, 2011 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Water dripping sound coming from new refridgerator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan. This is the only source of water if nothing else is connected. Are you seeing and water anywhere.
Jan 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Trying to hook up a new line to the icemaker how do i know if the water is coming thruu properly?
before you hook up the line to the fridge, have someone open the valve to verify that water flows to the tube, once verified, hook to the inlet valve and your golden.
Sep 12, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Water leaking under the refridgerator
SOUNDS LIKE THE EVAPORATOR FAN HAS STOPED WORKING
Aug 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
May 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Apr 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
When i start my washer water does not come out yet it spins
Make sure that both faucets the lines are connected to in the rear are TURNED ON, and that the right ones are selected. (Left is usually hot, right is cold.)
Then make sure they are properly hooked to the right lines on the back of the washer.
Finally, set the washer for a brief cycle with COLD water only.
Mar 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
