Question about Home
Where can I obtain a new toilet seat for a Vieany Egg toilet? Thanks David
3 Suggested Answers
  • 2712 Answers
SOURCE: How to install Toilet Seat
Use a flat head screwdriver to pry open the plastic pieces that cover the screws. Using the same flat head screw driver, unscrew the large plastic screws holding the old seat in place. There are usually plastic nuts on the underside that you can hold on to while removing the screws. Remove the old seat. Clean the area where the screws were and dry thoroughly. If the new seat has an adhesive pad, remove the covering from the adhesive and put the seat in place. Thread the new screws through the holes and attach with the new nuts. If there aren't new nuts and screws, you can use the old ones, provided they weren't damaged during removal. Snap the caps covering the screws on the new seat in place. Be careful not to over tighten the screws! Since they're plastic, they can be easily damaged by a screwdriver!
Posted on Aug 27, 2008
SOURCE: I bought a new Nordic Ware microwave 4-egg cooker
http://www.gomestic.com/Cooking/Get-Boiled-Eggs-From-Your-Microwave.570709
Posted on Apr 18, 2009
How to keep an elongated toilet seat in place
If you mean that it moves about a bit ..... if you go on ebay you can obtain toilet seat retaining plastic nuts , they are quite wide and do offer a bit of grip. I have put rubber washers on the seat screw first, then some wide metal washers to compress the rubber washers and produce some friction ....then I have used the wide replacement nuts to tighten the assemlage of bits so they are applying some force and keepin the seat in place
worked for me and my daughtert so may work for you
You just need to produce sufficient friction to stop it moving
Jul 05, 2015 | Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
Toilet seat cracked need replacement and aprrox. cost
Hello. A new seat is available at any hardware store. Elongated seats cost anywhere from 20-40. If you need to have it installed it will be significantly more. House calls are generally at least $50.00. Be sure to get a price up front as it only takes 5 minutes to replace a toilet seat.
If you want to do it yourself, unscrew the old one and screw on the new. That's it. Joe
Thanks for choosing Fixya!
Jan 23, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
Have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
Apr 07, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Me top just broke
two screws at back of seat is two square caps lift caps there is either two philips screws or two flat head screws when you grab screw driver get a pair of pliars to hold nuts on bottom of the screws hold the nuts as you are loosening the screws then just go to the home depot or supply store you like get toilet seat that is egg shaped buy and put in old ones place
Mar 11, 2010 | Ergo Toilet Seat - Elongated -Curve -...
Is it easy to enlarge the holes on a koeler toilet
Enlargeing the holes will not turn out well.
Modify the seat to take the plastic bolts.
Hope this tip helps.
R/
David
Jan 19, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Lid to toilet tank as i dropped the lid and broke it.
Hello;
Go down and buy another seat for your toilet. Under the rim are 2 nuts 1 on each side. Unscrew the nuts directly under the back of the seat. When the nuts are removed pull the seat off and discard. Install the new seat in the reverse order.
Thanks;
Rich
RPM Northwest
Jun 11, 2009 | Home
Leaking toilet
check the seal between the tank and the toilet.tighten it as necessary. (not to tight! you will crack the ceramic). Mkae sure the tank is square to the toilet.
also the water inlet connector.
Nov 24, 2008 | Saniflo 013/003/005 Sanibest Toilet with...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
