Question about GE Dryers
How do I remove the lid off of a GE dryer
Model gfds140edoww
  • GE Master
  • 473 Answers
Directions above are for a Whirlpool dryer not a GE front load dryer.
To remove top panel--there are 2 screws going down through the front edge of the top panel. In some cases you need to remove the complete control panel to access those screws. Pull dryer main knob straight out away from control. You will see 1 screw behind knob (I think it is torx head). Remove screw and gently pry upward on sides of control panel. It should pop up off tabs. If you unplug wiring harness you can put control panel aside. Now you can see and access the 2 front screws. Remove those and raise panel front and pull forward slightly and lift off panel. Reverse proceedure to reassemble.
Posted on Apr 04, 2015
    Habit-Forming:
    Scholar:
  • 73 Answers
Pretty easy! Standing in front of the dryer, reach to the back of the control panel and pull the lid towards you, lifting up on the front of the lid at the same time. There's two clips under the front of the lid that holds it in place. One on each side You may need to do one side at a time, but if you pull the lid forward and lift up on the front... it'll pop right up!
Good luck, I hope I was of some help,
Bill
Posted on Apr 03, 2015
  • GE Master
  • 2,992 Answers
Try: http://www.appliancerepair.net/clothes-dryer-repair-4.html
They can probably help, especially if you have a reason to take the top off and it is not performing properly.
Posted on Apr 01, 2015
Where does the green grounding wire connect to the lid of my GE dryer?
theres a schematic in each appliance. look there, & if your not sure get a service tech so you dont do more damage
Apr 23, 2014 | GE Dryers
How to open the top of dryer
Usually there are two screws at the back holding the lid to the cabinet, remove these then push the lid forward
Oct 15, 2013 | GE Dryers
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
Model No.BBL333EB1WW My dryer is not heating what should i do?
check the heating coil which is located inside the dryers' right rear corner. Unplug dryer, open door, remove all screws, pry on top corners with a flat tip screwdriver, disconnect dryer switch, set panel off to the side, lift up on top lid and check to make sure coil is not burnt in half. Hope this helped tim
Sep 05, 2010 | GE DBLR333EE Electric Dryer
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
I have a top loading GE model WBB3300 that is making noise
Use a putty knife to push in the retaining clips (2) in the seam between the front panel and the washer's top, allowing front panel removal. Push tab at back of lid switch forward to allow lid switch to be removed from washer top. Remove screw on each side near top, allowing washer top to be removed. One at a time, you can unhook the suspension rods at the bottom by lifting up on the tub support frame and unhooking the rod. Lift the rod a little at the top and apply a wad of lithium grease in that ball and socket joint. Rehook the rod at the bottom, and move on to the next rod. Reassemble.
Nov 23, 2009 | Dryers
My ge gas dryer glides I suspect are bad model # NVL333GY0WW but I dont know how to remove front panel there are no screws only door hing screws how do I remove it?
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Dryer-Parts/General-Electric-Parts-NVL333GY0WW/General-Electric-Parts-58994.cfm
Shows a picture of the lid of your dryer. #7are the clips that hold the lid down. Locate them then use a flathead screwdriver to release them.
Oct 25, 2009 | GE Dryers
Dryer squeaking from drum bushing wear.
Try typing into Google the model # and on line manual and you may be able to get to it that way.
Jan 25, 2009 | GE DBSR453EBWW Electric Dryer
HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Mar 17, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
162 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
