Question about Refrigerators
How do I set the control to make the freezer colder. at present my freezer is acting like a fridge
  • 52 Answers
Freezer coil could be frozen and might have a defrost problem
Posted on Apr 02, 2015
How can I turn up the fridge settings. It's not cold enough
you need to turn down the settings of a fridge --the lower the number on the control knob the colder the fridge
it is the freezer that the system is reversed where the lower the number the warmer the freezer
Sep 06, 2016 | Refrigerators
What setting must my fridge and freezer be at. Thanks
RFA70 settings Controlling the Temperature of the Fridge Compartment The left hand control wheel on the front panel adjusts the internal fridge compartment temperature. The internal temperature should be 5?C or colder, although some sections such as the salad bin will be slightly warmer. The setting of the control wheel will depend on the location of the fridge freezer, the room temperature and how often the door is opened. The normal set point (marked by a 3 on the dial) is usually suitable. If you need to adjust the temperature turn the control wheel using a coin to avoid damage: Clockwise (higher number) - Colder Anti-clockwise (lower number) - Warmer
Here is a user manual go to page 6 http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Fridges/HBRFA60.pdf
APPLIANCE 911
Sep 04, 2016 | Refrigerators
Bush fridge freezer need coldest setting for fridge 1_7
freezers settings are the larger the number the colder the freezer as against fridge settings where the smaller the number the colder the fridge
Aug 29, 2016 | Bush Refrigerators
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
We did not receive a manual with our fridge and need to know what temperatures to set it at. It is a two door fridge with a bottom drawer freezer and digital settings. Can you helps? Also do you know how...
If you set both in the middle settings thats generally best. 1 is the on/off and compressor control to run the box temperature, the remaining will say colder /warmer, this can be misleading however as colder actually is colder freezer! not reefer box! so to max that one actually makes the reefer warmer and freezer colder!
Jan 12, 2011 | LG Refrigerators
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Freezer section is cold, but the refrigerator section is not
set to colder refrigerator ... not colder freezer!! the fridge is reliant upon air migrating into the area from freezer side! if you peg both controls to max , you get a warmer refrigerator , but colder freezer, the control that does not operate the compressor is the setting i mean, it usually says .. for coldest and everyone pegs it and its a common cause for a service call and people cant believe it, if you cant tell which is which set both to middle! evfen at warmest setting the freezer should still make ice and thats the test for freezers state1 can it make ice!
Aug 23, 2009 | Roper RT14DKX Top Freezer Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
