Question about Refrigerators
How do I know where to set the temp control knob
The freezer is not freezing
  • Refrigerators Master
  • 5,323 Answers
THE OPTIMUM SETTING SHOULD BE AROUND MEDIUM NOT TO LOW AND NOT TO HIGH, OR IT WILL DEFEAT THE PURPOSE HIGHEST SETTING IS ALWAYS A BAD SELCTION
Posted on Apr 07, 2015
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
Freezer freezes up
Your post says it is about a dishwasher, but I assume it is about a refrigerator. There is generally a knob in the refrigerator. That will control both the freezer and refrigerator. The fridge cools by a fan that blows cold air from the freezer to the fridge. That is also why food can freeze when it is in the back of the fridge.
Apr 01, 2014 | Fisher and Paykel Dishwashers
Settings. I want maximum freeze
block off some of the return air it pulls in near the floor. You will have to manipulate it back and forth and let it sit for at least an hour to moniter the freezer to make sure the coils dont start to freeze up on you. Good luck. Oooh yes, and dont forget the temp control knob
Nov 26, 2009 | Kitchen Appliances - Others
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
I am renting a house with a ge profile refrige model no PSS27SGPASS. My food keeps freezing in the refrige. I keep raising the temp but that does not help what can I do I do not have a manual is there a...
That model has a electric powered damper that opens or shuts to reduce or increase the flow of cold air from freezer. Sometimes they stick open and will not close. It's quite expensive to replace. And the temperature control board is also expensive. I believe it's time to talk to the Landlord and get them on the project. Thanks, Sea Breeze
Aug 19, 2009 | GE Refrigerators
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Admiral Model AT17M6W - Temp Control Knob Stuck - Now I Broke It?
you will have to take the inside panel off the door to get to the back of the switch..Inspect it closely for sharp edges as all should be smooth on the swtiching mechignism.. if its broken remove the out part of the switch and see if you can turn the temp switch inter control shaft either way...if it keeps spinning then you'll have to replace the entire swtich(ording parts) if it doesnt spinn freely then plut the inner pannel back on but with the swtich house off so the dial rod sticks out...Kind of **** but it would work!!! hope this was helpfull:)
May 19, 2009 | Maytag MZD2766GES Side by Side...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator side is freezing contents
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Jun 10, 2008 | Kenmore Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
