Question about Garden
The leaf blower will power on but when you turn the speed up it dies
  • 448 Answers
It has air fuel mixture problem carb. Needs adjustment but depending on the year of machine may have to go to shop or dealer to be adjusted.
Posted on Jul 02, 2015
  • 4 Answers
SOURCE: PoulonPro Leaf Blower will not run properly
the carb has a screen in it it needs to be cleaned out the fuel gets crystalized in the carb when it sits for a while. and if the carb has a high and low on the carb meaning 2 screws on the side of the carb .one is for air and the other is for fuel try this first start it up and give it full throttle and turn the high adjustment till it does something screw it in slowley and or out till it is at full rpm sometimes the adjustment screws do vibrate there way out of adjustment .if it dont work then take the carb apart to clean out the screen
Posted on Nov 14, 2008
  • 211 Answers
SOURCE: craftsman leaf blower
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Posted on Dec 05, 2008
  • 76 Answers
SOURCE: Leaf blower does not respond when increasing throttle and engines
Unit is either having trouble picking up enough fuel or muffler is plugged. First disassemble the muffler and check that the flame arrestor screen is not clogged. Clean as needed. Cost, $0. Check fuel pickup line from fuel tank to carbureator for cracks. Replace if brittle or cracked. Next would be to check the diaphram in the carbureator. Even a small hole or crack can cause this problem.
Posted on Mar 31, 2010
SOURCE: My Homelite Zip start Leaf Blower dies when I turn
Gas Aluminium Cable head is broke.
Posted on Apr 06, 2010
SOURCE: loss of power leaf blower - gas
Had the similar problem- start with removing the exhaust intake plate 1st--- clogs with super fine dust initially then larger particles... Mine was completely clogged- cleaned er' out now she blows like the wind!
Posted on Jun 11, 2011
Runs slow
In California the new blowers have sealed mixture adjustments and you need the have your carb. mixture adjusted be a qualified shop. If your carb. HAS mixture adj., turn the high speed mixture so it runs best at high speed, then turn another 1/8 turn counter clockwise to be a little rich. Then at idle adj. the other screw till it idles best.
Apr 21, 2014 | kawasaki Krb300a Backpack Leaf Blower
Dies at high speed
Most likely its just a simple carburetor adjustment. Find the adj needle labeled "h". Turn that screw counter clockwise 1/4 to a half turn out. This will richen the mixture and should run like a champ
Nov 19, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
2 cylcle engine may start but des
Fuel filter or carb screen may be plugged. Screen should be replaced, not cleaned.
Aug 19, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
I have a Silver Eagle III leaf blower/vac. engine surges
Try turning the high speed adjustment screw counterclock wise a little at a time and see if that helps.
Mar 24, 2009 | Garden
Homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Stihl leaf blower motor dies when i try to give it full throttle
If the low and high speed screw are adjustable give them a try. Start with one turn on the low and two turns on the high speed. If these screws are fixed then you will probably have to put a carburetor kit in the carb. I hope this has been of some help. Donnyb60
Mar 18, 2009 | Garden
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
