Question about Epson Workforce 610 All-In-One InkJet Printer
How to fix the paper feeding mechanism
Possible gear malfunction
Broken plastic gear in lower paper feed
That sounds like a fairly simple fix - using your printer's model number, do an online search for replacement parts. If you're fairly handy, you should be able to do the job yourself. If you have a friend or relative who's handy, they should be able to do it. A typical commercial shop will probably charge quite a lot of money (possibly more than the price of a replacement printer) to do the job.
Jul 22, 2014 | HP PhotoSmart Office Equipment & Supplies
Canon i70 printer clicks when paper is loading
Joseph,
I have the same exact issue with my Canon I-70. I like to attempt to fix things on my own so I opened it up and discovered that one of the main gear wheels that operate the paper feed rod is cracked. I am not sure if it was always like that (I doubt it), but the whole gear wheel is cracked so the gear teeth have separated a bit. When the printer attempts to feed the paper the gear turns and when the cracked side where the teeth are separated hits the other gear connected to it the misaligned teeth do not allow it to proceed. Honestly it looks like a very simple change of the gear wheel will solve the issue. My problem is that I do not know where to buy this piece.
Can someone help me to find the specific gear wheel?
Jun 04, 2012 | Cannon i70 Printer
Cd stuck in player
sometimes a butter knife and a lot of patience works but other times i found it easier to remove the head unit and disassemble it. Its a pain but itll save the cd and your lens from any possible damage
Jan 24, 2011 | JVC KD-G110 CD Player
My printer pixma mp780 is Writing #357, whats wrong I have made my maintenance, Bottom clean.
Hi
This is an error message which refers to the position of the paper feed unit,or if the sensors that detect the paper is malfunctioning.
Take out all the papers,fan them a little and also unplug the power cord from the printer
Now,press the power button on the printer and hold it for 15 sec,to perform a power flee.
turn on the printer put,the papers back and check if it works out
it is possible to fix if you have 3 to 4 hours to kill, you have to dissasemble the printer completley and split the main unit inside into two(sheet feed and cassette feeder) they are connected by 4 screws, correct the timing(marks in red) on the gears auto sheet feeder and cassette feeder on both units and and rotate the cam shaft assembly to the start position
takes time but the fix works.
Nov 02, 2010 | Canon Office Equipment & Supplies
Canon all in one pixma MP 780 problem code ##357
Hi
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper jam error on Canon iP6000D
Hi Demo.
By the big gear...Do you see a clutch "with a hook like" plate ...check to see if it moves freely.
It sound like manual clutck is slipping .
Feb 25, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printer
What kind of back door do you have on your machine. Does it have a knob that you twist to get it off or does it have pieces on the left and right you have to pinch to get it off. Reason for asking....
There were two versions of this machine put out that had two different service stations and paper feed mechanisms. One version had a motor for the paper feed mechanism and a motor for the service station. The other version just had a motor for the paper feed mechanism and service station movement was tied in to this motor This was done with an altered gear mechanism in the service station. This gear mechanism was cheap and it broke easily. When it breaks you get a knocking/grinding noise and no paper feed or service station movement. It can't be fixed.
THIS PROBLEM IS IN THE MACHINES THAT HAVE THE PINCH OFF BACK DOOR!!!
Hope this helps.
Inkworks
866-381-0541
Oct 13, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Lexmarkx73 Won't feed paper through while printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Epson Workforce 610 All-In-One InkJet Printer Logo
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
