Question about Watches
How do you set a bat man digital watch TM &c DC comics(s14) BAT4000LR41 1114
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
I need to know how to set my skmei watch
I need to change date and time for skmei 1065 pls help me ;)
May 07, 2012 | Watches
Trying to set the time on a point zero brand digital watch. help!
Where's the crown on a man's point zero watch?
Jan 25, 2011 | Bulova Watch
Analog hands show 2hour 15minute ahead of the digital time. Can swap time zones fine, but the time difference remains. Cannot synchronize as per manual because cannot get eco-bat -1 set point. How to...
I have read the instructions and theyare as clear as mud!
If you haven't already tried it, try foll0wing the "local time" setting instructions, with reference to the s#last section "If necessary perform setting..............." This should either alter the hands or the digital display, so that you can get them to agree.
If you still cannot set your watch, then you might find it useful to go to Tissot.com and click on "contact us" and send them an email explaining your problem.
Mar 14, 2010 | Tissot T Touch Navigator 3000 T96.1.488.42...
I don't know what size battery my pulsar watch uses
OPTIONS:
1. Owners manuel
2. Take watch to walmart(or other) and have them replace bat (usually, no labor charge.
3. Bat is sometimes stenciled on case back (very small)
4. Open watch(IF YOU KNOW WHAT YOU'RE DOING) you can easily ruin watch. Check # on old battery or if missing check inside of back case
for # .
Sep 26, 2009 | Bulova Watch
Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Mar 14, 2009 | Seiko 0512037FA Wrist Watch
Flashing digital display
I just managed to solve this problem. Turn the digital face to the first screen which is probably flashing EOL with date. Then pull knob out as if you were going to set the time. Hold in two auxilliary buttons, you should see BAT come up on the screen. That should be it stopped flashing!
Dec 25, 2008 | Tag Heuer Kirium Formula 1 Chronograph...
Setting all the features of this man's digital sports watch
You gonna laugh at this: Scan your manual in your scanner and save on your PC. Then use ZOOM tool to read it.
Isn't it brilliant solution?
Dec 19, 2008 | Columbia All Sport Digital watch
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
