Question about Kitchen Appliances - Others
Do you know where I can purchase a Lectrix Toaster (with the breadbox) or how to fix one where one side won't heat and the handle won't stay down. Thank you for any suggestions!
One side doesn't heat and handle won't stay down.
hardrocko
  • 1476 Answers
SOURCE: another problem comes up....
You definitely have a problem with the hold down circuit. You will need a DMM. If you don't have one they are fairly inexpensive now and with a little reading of the instructions you should be able to master their use. Look for a fusible resistor. It should be a small shiny canister, pointed on one end flat on the other, with metal leads on each end and inline on the wire to the hold down mechanism. Once you find this, with the DMM on resistance setting (continuity), check across the device. If the DMM says infinity, in other words it shows a 1 and the display never changes, this is your problem. Replace it with a new one. They protect the device from runaway heating and are set to open at predetermined temps. Replace it witht the same rated device. Available at most electronic stores. The rating should be in centigrade (such as 160, 180, ect). This should solve your problem. You cannot solder the thermal fuse in as solder will melt when the toaster gets hot. It must be crimped to the wire. Sounds like your almost there. Good luck.
Posted on Jul 20, 2006
snakehead
  • 1074 Answers
SOURCE: Toaster broken???
these toaster has to be pluged in so that the lift lever could stay down.
Posted on Feb 25, 2007
SOURCE: Digital Display no longer showing, lever won't stay down
jsullivan22 is right about the diode. I have this problem with my 24502, which is a dual version of this. There are 2 circuit boards in your unit one with the LED display on it and another one. The diode needing replacing is on the other board. it is in the center of the board, right next to a large (1/2W or 1W) 2K ohm resistor. The diode is probably part number 3ez24d5. Test it with the diode test on your DMM, if it is bad you will get 0V both directions (I think). Also if you measure it with the Ohm function it will probably measure less than an Ohm (check the zero on your DMM as many are not accurate down this low) You can probably replace it with a <a id="ctl00_ContentMain_CartGrid_grid_ctl02_ctl00_lnkManufacturerPartNumber" href="http://mouser.com/Search/ProductDetail.aspx?R=1N5934BGvirtualkey58410000virtualkey863-1N5934BG" style="font-weight: bold;">1N5934BG</a> or a <a id="ctl00_ContentMain_CartGrid_grid_ctl03_ctl00_lnkManufacturerPartNumber" href="http://mouser.com/Search/ProductDetail.aspx?R=1N5359BGvirtualkey58410000virtualkey863-1N5359BG" style="font-weight: bold;">1N5359BG</a> Mouser stocks both of these&nbsp; (currently). I haven\'t gotten my parts so I can\'t guarantee these will work, but I\'m pretty sure. I will try the latter first as I\'m hoping it\'s higher power rating will keep it from burning out again, although I will be buying several spares. <br><br>This is clearly a design issue with these toasters and one that could be easily corrected. Both circuit boards in my toaster are very toasty in the area of these diodes, although I\'m sure the fact that these boards are mounted very close to the heating elements doesn\'t help their longevity.<br><br>Hope this helps everyone.
Posted on Jan 31, 2009
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
SOURCE: problem with the CUISINART RBT-450BKPC costco toaster
We had exact the same problem. Our problem was within the circuit board controlling the release relay, on the left side. 3 parts was dead:
1) rectifier diode 200V 1amp
2) Electrolytic capacitor 220uF 25V
3 Zener diode 12V 1W
These components supplies 12VDC to the rest of the circuits from the mains, 127 VAC.
Posted on Jul 06, 2010
Fix sunbeam 3806 toaster that won't stay down and therefore heat bread.
Just a guess since I have had the same happen to my Proctor Sillex - When you push down the lever, you are actually completing the transformer frame that then magnetically keeps the toast down until it's setting lets the toaster pop up.
In my case, a piece of toast was wedged and I could not get the handle down so that the hardware was in place to magnetically hold. Have you tried to give your toaster a good thorough shaking upside down, unplugged over the garbage can or the sink?
Good luck Eric
Oct 04, 2017 | Sunbeam Kitchen Appliances - Others
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
Toast will not stay down in toaster when lever is depressed, actually lever will not stay down. how to fix it?
Most times this is caused by a build up of crumbs in the bottom of the toaster. There is a small electo magnet that holds the lever down, if it gets covered in crumbs it won't work. Take it outside turn it upside down and bang the heck out of it till everything comes out. If this does not work then check and make sure the magnet is still attatched inside. Other than that, this toaster gets terrible reviews from folks with issues just like yours. I can only assume the electronics are failing on these units far to quickly. It can be repaired if yuou send it in to the manufacture but that is really not economical. I hope the upside down banging cures the problem.
Jul 03, 2011 | KitchenAid KMTT200 2Slice Toaster
The left side of the toaster does not stay engaged...if I hold it down it heats up but it doesn't stay down ..it doesn't catch.
There are two printed circuit boards inside front of toaster - One PC board for each side. The circuit board on the side that won't latch down in the "toasting" position , is defective. Now, does anyone have access to a schematic for this toaster?
Jul 02, 2011 | Cuisinart CMT-400 Cast Metal 4-Slice...
Problem with the CUISINART RBT-450BKPC costco toaster
Apr 25, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Aug 04, 2009 | Kitchen Appliances - Others
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
GE 169137 Classic 4-Slice
have you tried to turn up the heat thermostat on the side.
Jul 10, 2008 | GE 169137 Classic 4-Slice Toaster
Kitchen Appliances - Others Logo
179 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
