ResMed S8 Elite CPAP screen displaying ;System Error; what fixes this?
The unit was blowing air for 15 to 20 seconds then stopping, now it does nothing. the screen was just displaying ,System Error, After leaving it unplugged for a bit, it now comes on with the Welcome screen then says ,High Leak in Last Session,, but then touching any other button sends it back to ,System Error,. How do we fix this? Please!!! I'd really appreciate an answer. My Dad is using trying to use it. He is fighting bre ast Cancer, on top of that his nasal drainage is causing him to cough and the only place he can sleep now is leaning at the kitchen table. Please Help
Shuttle83
  • 1139 Answers
SOURCE: Emerson EWF2705, when pressing power it sounds like it is coming on but nothing happens
Hello DEBM,
The problem with your television appears to be in the high voltage power supply or the low voltage power supply. The set tries to come on but the shutdown circuitry turns the TV off. The shutdown circuit is a protective measure put into place to prevent overcurrent and overvoltage conditions by shutting down the TV when these conditions exist. If you do not have a background in electronics, might I suggest that you have a TV technician to come to your location and work on the TV.
I hope this helps
Thabk you,
Shuttle83
Posted on Oct 17, 2007
SOURCE: Uniden DCT648-3 "welcome Please Wait"
You need to replace the battery
Posted on Dec 25, 2007
SOURCE: Water spillage in Dimplex portable air conditioner
Hi Leanne,Bung stays in and you dont take it out until the red light (4th on right on top of unit) comes on, then you empty it taking bung out and use tube to get the water out. It will probably take some time (days of continuous operation) for the light to come on, depending on your humidity etc. For easy emptying, wheel the unit to a bathroom or outside where if it spills a bit it won't matter.
Ours is working okay although it just stopped blowing cold air and is only blowing room temp air. we have guests tonight and its hot! I came here looking for a solution to my prob and found yours!
chhers, Les.
Posted on Jan 08, 2008
  • 9 Answers
SOURCE: Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Posted on Jun 08, 2008
koolbreezes
  • 540 Answers
SOURCE: AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Posted on Jun 18, 2008
How do we fix this error on Fisher&packel CPAP?
Error codes 5.0 to 5.8 indicates a problem with the motor.
Try removing the unit from the power outlet and then plug back in.
If error code persists technical manual recommends returning unit as motor problem.
http://www.vivisol.nl/assets/uploads/services/ICON_.pdf
my take on it !
also check the little filter at the back of the unit and blow the dust out of it. You will be surprised how much dust is filtered out by this filter. .
NEVER move the unit without emptying the water out of humidifier first !!!!
Jan 24, 2017 | Washing Machines
I need top cover for my humidifier part number 324866-301 does anyone know where I can find one?
Shop for Humidifiers' top cover on Google
CPAP.com - H4i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../resmed-h4i-heated-humidifier-top-cover-seal.html
People Who Bought H4i™ Heated Humidifier Top Cover Lid and Seal Also Bought. ... This is the plastic cover used with the Resmed Humidiare H4i Heated Humidifier. ... People Who Viewed H4i™ Heated Humidifier Top Cover Lid and Seal Also Viewed.
HumidAire 3i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../H3i-Heated-Humidifier-Top-Cover-and-Seal.html
This is the plastic cover used with the Resmed H3i Heated Humidifier. It also includes the plastic gasket below the tube connector.
Sep 29, 2015 | Humidifiers
How to adjust pressure on resmed s9
I think you are talking the the RESMED S9 CPAP Machine. If so,
1.Press the Setup button and the Push Dial (see first image below) for 3 seconds.
2. Turn the Push Dial until you see the Options Screen (see second image below).
3. Press the Push Dial once to select the Option Screen.
4. Turn the Push Dial until Set Pressure is highlighted in blue.
5. Press the Push Dial once. The highlight should now be orange.
6. Press the Push Dial once. The selection should change from orange to blue.
7. If finished, turn the Push Dial until <8. Done!
Jan 29, 2013 | Health & Beauty
My Aeiomed Everest 2 unit no longer blows air. The display powers on but shows a "Unit Shut Down Mode 4" error message. That message is in their manual (under troubleshooting) but offers no...
Mine did the same thing 3/29-3/30/2011 about 4am. Called my home care place of course they have new no clue. Email me if you find solution please. rrs375@yahoo.com
Mar 29, 2011 | RTO Aeiomed Everest 2 CPAP, Humidifer and...
My 3 yr old Respironics CPAP has stopped putting out the pressure it is supposed to. Still works and still show 12.5 Lb - but is 1/2 as strong - maybe less.
if have pressure gauge u can check that if your using a manual machine the pressure will be constant as the set pressure is 12.5 and there will be ramp which will start with lower pressure and reach to 12.5 as per the set timings and if you are using a automatic mcahine no need to worry.
Mar 17, 2011 | Respironics Health & Beauty
Kenmore elite washer model 21082000, won't
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 19, 2010 | Kenmore Elite 21082
Kenmore elite trio refridgerator with an error code ER FF
ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message2.gif will be displayed. This fridge2.gif is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer2.gif where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps circulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator2.gif which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
Good luck
Oct 05, 2009 | Kenmore Refrigerators
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
What do these error codes mean?
FH
No water detected entering machine or pressure switch trip not detected
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.(usually this will be failed pressure switch. the hose should be replaced as well)
Jul 20, 2009 | Kenmore Elite 45986 Front Load Washer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
