Question about Dell Inspiron N5030
Dell-n5050 laptop; windows failed to start; code-0xc000000e; boot failed because required device is inaccessible. I have Dell OS media stick. and is there a free fix for this problem?
    Sergeant:
  • 139 Answers
That code is a Windows boot error. I'm not sure what you can do with the Dell OS media stick but the traditional solution with a regular hard disk is to take a Windows 7 OS disk, boot with it, and run startup repair. Here's a link to Startup Repair: Startup Repair Microsoft Windows
Posted on Apr 01, 2015
CODE Oxc000000e. says required device is inaccessible. i have the Dell os and recovery and restore key. what do I do next
your bootmgr is not working right,it cant boot up,download this and put it on a cd and run it, EasyBCD
Apr 01, 2015 | Dell Inspiron N5030
How to format my Dell computer
Your drive may be toast. You need to find the right F key (typically F2 or F8 or F12) to open the BIOS menu. Start pounding on one while booting until you find it. You may have to try all 12 F keys. Once you get the BIOS menu (not the boot menu), there should be a device section. Make sure your C: drive is visible to the BIOS. If not, the drive is usually bad and needs replaced. You will need a drive preloaded with WIndows, or you will also need the Dell recovery CD set. However, if the C: drive looks OK, next find the right F key to open the boot menu. There should be options there to boot Windows, Safe Mode, Restore to a previous check point, or recover to factory settings. If this does not work, you will need to get the Recovery CD set from Dell for your model. Be warned this usually destroys all old data files.
Jul 25, 2014 | Dell Studio Computers & Internet
I cant remember my password to get into my dell inspiron n5050 home premium with windows 7
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Apr 15, 2014 | Dell Inspiron 15 (N5050)
I forgot my password for my dell inspiron n505 home premium with windows7 how do i reset the password so i can use my computer
Hi, my dell laptop having problem I have a
Press F8 when starting up to get into safe mode, then use system restore to revert back to a previous working state
Aug 10, 2013 | Dell Inspiron Computers & Internet
Windows 8 error code 0xc000000e
Hi I have this error code 0xc000000e windows 8, You get three options,
1. Enter to retry
2. Press F8 for start up settings
3. press F9 for to use a different operation system.
First two options do nothing, F9 will restart computer, and the I can boot from the boot disk. I have tried to rebuild the startup files, from the disk nothing is working. I can't get into the Safe mode. Guess only option is save all files to a back up HDD, I even tried to restore to a past date.
Nov 17, 2012 | Computers & Internet
0xc000000e
1. First Load Windows Recovery environment from Windows 7 or Server 2008 R2
2. Open Diskpart and make problematic partition Active
3. Open bcdedit and you should get something like this:
Windows Boot Loader
identifier {default}
device unknown <===0xc000000e problem!
path \Windows\system32\winload.exe
description Windows Server 2008 R2
locale en-US
inherit {bootloadersettings}
recoverysequence {e0025536-b36d-11de-aadd-ddc0b5870e2c}
recoveryenabled Yes
osdevice unknown <===0xc000000e problem!
systemroot \Windows
resumeobject {e0025534-b36d-11de-aadd-ddc0b5870e2c}
nx OptOut
hypervisorlaunchtype Auto
4. Enter these commands:
bcdedit /set {Your-OS-Identifier} device partition=X:
bcdedit /set {Your-OS-Identifier} osdevice partition=X:
bcdedit
Where X: - drive letter with your problematic OS in Windows RE. You can find it by opening notepad and pressing save
5. Reboot
if you don't have a copy of the dvd you can try and boot to a recovery partition by tapping f8 @ boot and you should be able to go to 'repair my computer' and hit enter. you can also download the recovery console from the internet and burn it to a cd and run it. good luck
Feb 11, 2012 | Toshiba Computers & Internet
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
Dell Inspiron N5030 Logo
123 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
