Question about Music
What is the price of td 10 mother board - Music
  • 2,992 Answers
Try ebay, or thefind.com
Posted on Apr 01, 2015
FCan get my Ipod to play through my Roland TD-20 Mudule
You need to get yourself a cable - with a 3.5mm male jack plug on one end (which will fit into your ipod), and a 1/4 inch male jack plug on the other end.
(you could use a lead with a 3.5mm male plug on each end, and used a 3.5mm female to 1/4 inch male adaptor to achieve this)
Connect the 3.5mm end into the ipod - play a track, with the volume at say, 75%.
Connect the 1/4 inch end of the cable to the 'Mix In' input in the back of your TD20.
Use the 'Mix In' control - at the top right hand side of your TD-20 module to control the volume.
If you wish only to have the iPod going to (for example) headphones - and not Front Of House (PA) speakers - which you will have connected via the Master and / or Direct Out(s); this can be achieved in the 'Mixer' settings (accessed via pressing the 'Mixer' button).
Oct 22, 2012 | Roland TD-20X V-Drum Sound Modul
2009 212 40 watt mk2 in shop mother board went out is this common and what would cause it
"Mother board went out" is a statement of a tech that is incapable of troubleshooting things to the component level. Most common things are broken pots and connectors. There is nothing common to cause a "motherboard to go out". You should find a tech capable of analyzing the problem that has proper test equipment and skill to repair the unit. There is likely a part with cost less than $2 that has failed. Common problems include: broken connectors, broken pots, circuit board cracks, Bad solder connections. Bad solder and bad jacks are most common with bad pots third in line. Bad electrolytic caps are next in line.
Jun 13, 2011 | Line 6 Spider Valve MkII 212 40 watt 2x12...
The cable assigned to my roland TD 4 mesh snare is not registering. I thought it a cable problem so a replacement was shipped however still the same prblem. I have ensured the settings are right so I'm...
You may have a bad solder joint where the jack for the snare trigger input is soldered to the circuit board. You will have to open the case and have a look. Make a note of how many screws and where they go etc. If you have a digital camera, take pictures as you go. We have a TD3 and it has two circuit boards one on top of the other.
Nov 11, 2010 | Roland Pd 8 Dual Trigger Pad
My USB port enter part came apart from the mother board.
If it is the connector, resolder the connector to the board, carefully...
If the connector is damaged, you can get new ones from several sources, including Digikey.com and Mouser.com.
Also consider finding a connector to salvage from PC recycling outfits.
Sep 05, 2010 | Vestax Vci 100 Midi Controller
The headphones output on my roland td- 10 is sending sound just to a single channel ,I test it with diferent headphones ,same thing.
The owners manual is here:http://lib.roland.co.jp/support/en/manuals/res/1811143/TD-10_eG.pdf Try initializing the TD-10. Check page 137. Check page 132 and 133. If the problem is still there, you likely have a jack problem. There might be a bad solder joint where the jack is mounted to the circuit board. If the warranty is up you can do it yourself if you are confident. Otherwise take the module in to have it serviced. Check here to contact Roland:http://www.roland.com/index.html
Aug 31, 2009 | Music
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Music Logo
18 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
