Question about Sewing Machines
How do I put the bobbin holder back in my machine after cleaning it?
  • Sewing Machines Master
  • 9,272 Answers
Don't know the brand or model, so just guessing here.
Most bobbin cases have a latch that needs to be released before it can be removed and again while it is being inserted. Be sure to hold the latch open while inserting it, wiggle it a little bit until it seats itself, then release the latch. If the bobbin case is not properly installed, it will continue to fall out when you begin to sew.
Posted on Apr 03, 2015
    Master:
  • 395 Answers
The same way you removed it. Backwards:
Posted on Apr 01, 2015
  • 2,963 Answers
Owner's manual is usually quite clear. No manual?
Try manualslib.com
How do I get the bobbin to thread after I put it back in the holder.
Do you have the bobbin holder threaded right? You have to put the bobbin into the holder and follow the thread path, then pull it up to the top and turn the needle by hand until the thread picks up the bobbin thread. then pull both threads up and to the back then slide your bobbin plate back into the machine and you are ready to sew. Hopes this helps. wish I could draw you a picture.
Jan 10, 2015 | Sewing Machines
My bobbin holder flew out of my sewing machine and I can't get it to pop back in kenmore model 16524000
THE BOBBIN CARRIER IS WHAT FLEW OUT. THIS IS PUT IN BY ROTATING YOUR HAND WHEEL SO THE NEEDLE IS AT IT'S HIGHEST POINT. THEY'RE IS A SPRING THAT HOLDS THE CARRIER DOWN IN THE MIDDLE APPROXIMATELY. IT IS A LITTLE PIECE OF METAL BUT REALLY IS A SPRING. AS YOU PUT IT IN YOU WILL NEED TO PULL UP ON IT A LITTLE IN ORDER TO SLIDE IT IN. BEFORE YOU DO GO AHEAD AND CLEAN THE RACE THE CARRIER LIES ON AND PUT A DROP OF SEWING MACHINE OIL ON IT.
Nov 13, 2014 | Sewing Machines
How to put bobbin attachment back together and then....thread a bobbin! lol
hi, this webpage contains a manual that show you how to put the whole section back
http://www.searspartsdirect.com/partsdirect/user-manuals/3116-singer-parts-SEWING+MACHINE-manual
Regards
Rob
www.electronicrepairs.co
Dec 28, 2013 | Singer 3116 Simple
I would like to oil my elna 6003 but the manual does not show where to oil.
I'm pretty sure these have a wick in the rotary hook under the black plastic bobbin holder where the bobbin sits. Everything else is nylon gears or designed to be lubed during your annual recommended service by an Elna technician.
You can oil the wick yourself (don't do what I did and pull it out with tweezers, dooh). Take out the bobbin holder black bit (your manual should cover this in cleaning) and see if there is a depression/hole in the middle of the metal rotary hook. If so, just put a drop of oil in there once every couple of months.
More important is to clean out the rotary hook well regularly and everywhere else in there, just use the little brush to collect the lint, then wipe it off on a piece of cotton fabric waste to clean the brush, then clean a bit more until no lint remains. Now put the bobbin holder/case back into position lining up the marker point against the stopper. Done.
Hope this makes sense to you and matches what your machine looks like. Happy Sewing, Tally Girl
Sep 17, 2011 | Elna Quilter's Dream 6003Q
I have a Janome 4900Qc which has the sign Stop for Safety Purposes, this comes up really often, it has been back and been checked but no better now
Are you having thread jamming problems before you get this message?
I found that my bobbin holder which is held by magnets was being dislodged when I had a thread jam up, usually when I was trying to sew something very thick over a seam such as jeans hems.
Have you mastered removing the needle plate and the bobbin holder to clean in under it and putting this all back together again? With my 6500P, the needle had been striking the bobbin holder when it dislodged and rotated out of postion, the bobbin case had holes and damage to the plastic which was then catching the thread as the bobbin rotated making the jams happen.
Each time, I would dismantle the bobbin holder, clean everything, cut the jammed up threads, check the bobbin case and give the damaged bit a file with a nail file to make it smooth again, then put it back matching the red markings on the bobbin holder and the stopper, rethread and start over. I have bought two new bobbin cases too and taken it back to the dealer a couple of times over 5 years.
I've now learnt to not try to stitch over the thick seam intersections, I'll stop before, lift the pressure foot, move the work past the seam, then restart sewing. However, my machine was just serviced last week and it looks to me like the mechanic has added a part to hold the bobbin case in better, its like a little black lug on the left screwed into the outer housing. So perhaps Janome have addressed this issue with an aftermarket repair.
Apologies if this is telling stuff you already knew, good luck.
Mar 07, 2011 | Sewing Machines
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
I took out parts of bobbin to clean and when put them back the needle hits the metal of the bobbin case and i cant sew. it doesnt seem to be properly aligned.
Perhaps remove the bobbin case and check that you have put it back correctly. Check with the sewing machine manual to see how it is done correctly. Make sure that the top of the bobbin case is at the top of the bobbin case holder and make sure you change the needle as it will probably be dull or bent from hitting the metal of the bobbin case.
Aug 27, 2010 | Bernina Activa 130
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
Bobbin holder
Make sure the needle is in the highest position before you try putting the bobbin holder in. The bobbin holder has a metal 'finger' which fits into a 'slot' in the housing and it only goes in if you have the needle up.
Mar 31, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle won't pick up bobbin thread - HELP!!!
I recently fixed my wife maching with the same problem. I found that the screw had come loose that holds the linkage together that rotates the bobbin holder. I was fortunate enough to notice the screw while looking at the machine. To replace it requires taking both the front and back covers off of the frame since the bobbin holder linkage is in the rear behind the needle area. Be careful to insure that the plastic toothed "rail" that runs the bobbin holder is positioned properly or it may break off a tooth. Once I replaced the screw and put the machine back together, it picked up the thread with no problem. Hope this helps.
Dec 27, 2006 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
