Question about Car Audio & Video
I have 2 pro vision 9" headrest monitors I bought with no plugs need to know how to hard wire it to bypass the plug
Noggin
  • 944 Answers
SOURCE: XO-2703 WIRING
Try these guys - although they only allow installation by licensed installers, so they may not supply parts. http://xovision.com/contact.htm Wiring harnesses for this type of application will differ considerably from vehicle to vehicle depending on the location of the monitor and player and the route through which cabling has to be threaded, so they are usually constucted in situ. The connectors on these units should be standard, so any auto electric shop should be able to wire it up, but be careful not to void any warranty on the monitors. Hope this helps :)
Posted on Mar 19, 2007
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
SOURCE: CANT HOOK UP MY TVIEW T56UN/HR 5.6 LCD MONITOR
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
Posted on May 15, 2009
SOURCE: cant play dvds at all because of parking brake, and wanted to know the process of fixing either wire or bypass codes
in the back of your radio were your power cables are at theres a brown wire with the words parking brake on it all you have to do is connect that to any place to were you have ground even to the ground cable that your radio is connected to
Posted on May 20, 2009
  • 3 Answers
SOURCE: Need the schematic for a Videoman JCS-701 rear camera monitor so we can wire a new plug for the back of the monitor. Someone cut off the old one.
facing the rear of the monitor, the two round 5 pin plugs on the left are the rear camera plugs on the far right four pin square plug red cable terminal 15 ign power... black cable terminal 31 neg battery... orange cable back-up lights... white cable to hopper lights.., I have a full wiring diagram for the system if you needa copy e-mail me at ssmith01@charter.net
Posted on Jun 12, 2009
I have 9.2 concept headrest monitors but need the wires that goes from monitor to dvd player. were can i find this?
call concept at 1 888 830 1788. they are usually 29 to 39 dollars. you must specify if you have 6 or 8 pin feamle plugs.
Jan 16, 2010 | Concept Car Audio & Video
I cant figure this out about my headrest lcds HELP
Let me guess, you have a pioneerr dvd headunit a video amplifier and 2 headrest correct.
Now connect from V/A in at the headunit to V/A out at the video amp. Connect V/A out put from #1 headrest to #1 V/A in put at the amp. And V/A out put from #2 headrest to #2 V/A in put at the amp.
Jan 07, 2010 | Car Audio & Video
Xo vision gx2022..need the plug that turns video wire into rca's
radio shack online or crutchfield.com may have what you need
Dec 27, 2009 | XO Vision GX2022 Car Monitor
Walmart dual headrest dvd player has no sound on passenger side
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
Oct 09, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Monitor problem
Un Plug the monitor and let it sit for a few hours.
Jun 29, 2008 | Gateway FPD2275W LCD Monitor
No 9 pin video socket
Most video cards use a 15 pin VGA connector.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
Hope this helps!
Matt
Feb 29, 2008 | Dell Dim.9150 Pentium D 820 Dual...
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
