Question about Microsoft SideWinder Force Feedback Pro Joystick
My joystick has 9 pins. How can I convert this to use on a new computer?
Can't get null modem usb to 9 pin cable to transmit designs to machine.
First, to transmit to your machine using a USB to serial converter, it should have a FTDI chip. Second, you should be transmitting on Com 1 or 2 -- preferably Com1. You can change the port it transmits on in the Device Manager in computer properties on your computer. Third, check on your machine which port it's looking for -- they must match.
Sep 29, 2015 | Singer Quantum XL-5000 Computerized Sewing...
Need help adapting my J-ZA10 Wingman X to my desk top.... Can this be done????
Try Radio Shack
there are adapters to convert the 15 pin connector to USB which I assume your PC counts with
Indeed I have a Wingman Extreme joystick and I use one of these adapters
Apr 01, 2014 | Logitech J-ZA10 Wingman Extreme 3D...
Has new batteries, circuit breaker good, but no power to operate the chair. ??
tooker check the battery wiring to make sure that the batteries are wired in series ie positive of one battery to neg of the other etc. If I remember correctly the Jet 3 wire from the battery plug into two plugs located in the battery area. Make sure that those connections are good. Also check that the joystick cable is seated well into the 9 pin connector at the rear of the chair. If all of that is good take a digital voltmeter and set it to 200 volts dc plug the two leads into the two outter holes of the charger port located under the front of the joystick. You should read the battery voltage at 25+ volts when fully charged. If you don't read anything there is a bad connection somewhere take the meter and check the individual battery voltage then take a reading at the plugs coming from each battery to make sure you have voltage going to the power module. Take a reading at the rear of the chair at the 9 pin socket neg in the hole in the center and touch the positive lead to all the other holes until you find 25+ volts. If you have voltage at the 9 pin connector then the problem is in the joystick and could be the on/off switch. Let me know what you find and I will try to help further if I can
Jan 31, 2011 | Jet 3 Ultra Power Chair
I have an old wingman interceptor joy stick with a 15 pin connector for the computer. My new computer will not accept it. Can it be adapted to use the usb ports jerry
You can buy a 15 pin to USB adapter but for the cost of one you might be better off buying a new joystick.
http://cgi.ebay.com/15-pin-Gameport-USB-PC-Adapter-Flight-Joystick-/170571949307?pt=AU_Components&hash=item27b6e164fb
Dec 03, 2010 | Computers & Internet
The pins do not fit any of my computer conection
got to FRIES and ask for a db 15 female or male adapter to USB
Jun 17, 2009 | Kensington Gravis Blackhawk Digital...
Convert to USB?
i think you can order those, but if you have a USB stick you go to the products homesite and download a driver for mac =)
Dec 29, 2008 | Kensington Gravis Blackhawk Digital...
15 pin to usb
Yes there are some converters that you can use to plug your joystick to USB:
For example:
http://video-games.search.ebay.com/_Video-Games_W0QQsacatZ1249QQsassZwwwtvpscom
http://cgi.ebay.co.uk/USB-to-15-Pin-Joystick-Gameport-Converter-Adaptor-Cable_W0QQitemZ300178219822QQihZ020QQcategoryZ74943QQcmdZViewItem
Dec 10, 2007 | InFocus VGA Cable - 15 pin male-male, 4...
Warrior Compatibility
buy a connection from a "9 pin" to a USB output
Oct 02, 2007 | Logitech WingMan Warrior Joystick
Joystick problem
there are various sites that sell adapters, if you look at the link for example, although there are cheaper ones when you know what your'e looking for, hope this helps http://www.usb-port.com/rm203.html
Apr 11, 2007 | Logitech WingMan Attack 2 Joystick
Microsoft SideWinder Force Feedback Pro Joystick Logo
219 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
