Question about Lexmark Office Equipment & Supplies
My Lexmark X2670 printer will not print. The cable is good and I've printed from it before.
Is there a software problem somewhere? There is no communication now between computer and printer. The document stays in the queue.
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
Posted on Nov 06, 2008
yooperbud
  • 8637 Answers
SOURCE: Can't get Lexmark X5410 to print. Printer is on "Copy Mode"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
smartr10U
  • 1305 Answers
SOURCE: Can't print from MacBook, through Time Capsule, to Lexmark x5470
turn on the printer sharing via the system preference panel on the computer that is on the system via usb.
Then on your wifi computer look for shared printers and you'll see your printer in the list under the host computer name... use that setting and it should fire up for you!
let me know how it goes...
Posted on May 28, 2009
SOURCE: Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Posted on Jun 03, 2009
techbuster
  • 5081 Answers
SOURCE: Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Posted on Aug 19, 2009
Lexmark x2670 wont print colour red
You most likely need to go into the maintenance menu on your printer and perform a nozzle and/or head cleaning procedure. Your nozzle for RED is most likely clogged. Printers are designed to be used regularly and when they sit for a whikle unused they tend to get these issues. You may need to do it several times.
Feb 02, 2015 | Lexmark X2670 All-In-One Printer
My Lexmark x2670 wont print colour red
Make sure the magenta cartridge is not empty.
If it's not, then try the print head cleaning function in the printer utility window. In "Devices and Printers" select the printer in question to get the window
Printer didnt have a usb cable in the box, how do i complete setup?
rather than fuss with them go to walmart and buy one.. send the reciept to lexmark (if included) and they should refund you..
Jan 11, 2014 | Lexmark X2670 All-In-One Printer
Can you connect a printer lexmark x 2760 without a usb?
The Lexmark X2670 can only connect to a computer using a USB cable. Without it, your computer won't be able to communicate to the printer for printing, copying and scanning. If you lost the USB cable, you may purchase one from any retail stores. The USB cable used for your model has Type A plug on one end and the other end has Type B plug. You may also contact Lexmark Technical Support Center for additional assistance.
I hope this information has been helpful.
Jan 15, 2012 | Lexmark X2670 All-In-One Printer
My lexmark x2670 prints copys but it will not scan a document ocr it scans but will not process it .,then tells me it needs a program that has been deleated or lost i am using vista 32bit noel
You will need to update the printer software installed on your computer to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. Just re-insert the install disc into the computer hard drive and run the installation setup.
If you lost the disc, please contact Lexmark Technical Support Center for assistance.
Aug 10, 2011 | Lexmark X2670 All-In-One Printer
No. i want manual for x2670 printer
hi and welcome to Fixya!
You may view or print the manual for your printer on this link:
http://www.manualowl.com/m/Lexmark/X2670/Manual/35913
Hope this helps!
Takasashi
Jul 05, 2011 | Lexmark X2670 All-In-One Printer
I have the Lexmark X2670 and a couple days ago I scanned a document. Now I am not able to print anymore, I have items waiting to print when I check the printer, but the printer continues to print out...
Reset your printer by unplugging the power adapter from it(small black box behind the printer where the power cord is attached). Wait for at least 10 seconds before plugging the power adapter back in the printer.
Clear the print queue first before sending another print job. Follow the steps below:
Apr 07, 2011 | Lexmark X2670 All-In-One Printer
Please could you supply me with an installation CD for a Lexmark X2760 Printer
You either need the driver or the software studio, this model might
not have a studio, and just the driver so windows see the printer and you can print.
This is the download page for your product. Make sure you have the right model #.
http://support.lexmark.com/index?page=home&locale=en&userlocale=EN_US%20&segment=DOWNLOAD
Feb 05, 2010 | Lexmark X2670 All-In-One Printer
Lexmark X2670 printer not working with Windows 7
Did you upgrade the driver to a Win 7 driver?
If you did not, go to the Lexmark website www.lexmark.com Go to the driver download page and get the Win 7 driver for your printer.
Be very careful to follow the directions and completley remove the printer's software prior to installing the new driver.
Don
Jan 22, 2010 | Lexmark X2670 All-In-One Printer
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
