Question about Dell Inspiron 530 Desktop Computer
How do I determine if CMOS battery is bad - Dell Inspiron 530 Desktop Computer
    Problem Solver:
  • 9 Answers
Like they said above, your first clue will be that every time you power up your computer, the date and time will be wrong. It's the battery that keeps a small voltage across the memory so that the computer remembers that kind of stuff while it's switched off. You can run it that way, but you'll want to set the date/time to the proper values every time.
It isn't a big job to replace the battery. Simply open up the case, make a note of the battery's part number and orientation, etc. You may need to pop the old battery out. (It generally looks kind of like silver coin in a plastic socket on the motherboard.)
Save a few bucks by purchasing a replacement battery from a general goods store (e.g. Amazon, Target, Walmart, Kmart, etc.) or even a grocery rather than an electronics or computer store. They're exactly the same but usually somewhat cheaper.
Posted on Apr 02, 2015
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
I am guessing that you mean the back up battery about the size of an old UK half penny. First sign is usually that after a power outage the date and time revert back to original. I only get this problem on machines that have come out of use or are second hand. My advice to anyone reinstalling a machine after a period out of use is to install a new battery. It is false economy and possibly silly not to do so. If you are not happy doing it get someone who is happy about changing it and make sure its is correct way up.
If you have the permanently soldered in battery then I am afraid you will have to take it to a tech. Computers built like this often fall into the cr4p category and a use it and throw it away life! However the date again is an obvious first problem, It is also probably fairly old.
Posted on Apr 01, 2015
    Problem Solver:
  • 15 Answers
If you receive errors on boot up where the time or cmos shecksum is incorrect. The battery is cheap enough to just replace. If your error includes other issues like usb overcurrent errors then there is an issue with a broken usb port or a usb cable to the front panel to the mobo is connected incorrectly (+5v shorted to ground). fix the short or replace the mobo and the error will go away.
I have a dell precision m4300 laptop I have plugged it in to charge, I have noticed the battery light flashing red, I can get to login and nothing else,I also have noticed my laptop is getting very ho
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
clean dust from inside laptop
check your computer ram and cmos battery to make sure they have dust free secure seatings and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope this helps
Sep 09, 2012 | SIB USB External CD-ROM Drive for Dell...
Tip
CMOS Checksum error
<b>Issue:</b><br /> CMOS Checksum Bad or CMOS Date/Time Not Set<br /> <br /> <img src="matrix12_1.jpg" /> <br /> <br /> <b>Cause:</b><br /> This issue is caused when the CMOS values are incorrect. This issue can occur because of any of the below possibilities.<br /> * Bad or old CMOS battery. <br /> * BIOS update<br /> <br /> <b>Workaround 1:</b><br /> 1. Disconnecting power from computer without shutting down computer.<br /> 2. Attempt to reboot the computer. If error still occurs after rebooting the computer enter CMOS setup and check all values, this includes verifying the time and date are correct. Once everything has been verified and/or changed make sure you save and exit CMOS setup. <br /> 3. If you have a Phoenix BIOS and have an option for 'Reset Configuration Data', set this value to 'Yes' and save and exit the CMOS. <br /> <p>4. If the computer was had the power disconnected while it was still running it is possible this could cause the CMOS to become corrupt. Ensure that the computer is ready to be shut off before turning off the computer. If you have a laptop computer ensure that the battery is charged before disconnecting the power connection. <br /> 5. If the CMOS values have become corrupted entering the values in CMOS setup and saving and exiting CMOS should resolve your issues.<br /> <p><b>Note:</b> If this issue continues to occur after you turn off your computer off it is possible that the CMOS battery may be failing or already bad. Before considering replacing the CMOS battery try leaving your computer on for several days. <br /> <b>Workaround 2:</b><br /> <p>If you performed workaround 1 and the error occurs again after a complete power down (i..e. removing the power cord), the CMOS battery is likely bad. Most systems use a small coin style lithium battery. These often last 3-6 years, but at some point run out of juice and need to be replaced. For desktops, your system manual or motherboard manual should specify the type of battery and location on the motherboard. For laptops, it is often very difficult to access and may require a professional to replace it. To replace the battery on a desktop system:<br /> 1. Turn off the system and remove the power plug.<br /> 2. Remove the case or side panel to access the motherboard. <br /> 3. Look for a round silver coin cell, typically in a black holder.<br /> <br /> <br /> <img src="matrix12_0.jpg" /> <br /> 4. Remove the battery while noting which way the battery is located. You may need a small flat screwdriver to release the side clip. <br /> 5. Install the replacement battery with the same battery type, being careful to insert it in the same direction as the removed battery (or using the polarity marked on the holder or manual). <br /> 6. Reassemble the case and power. <br /> 7. Turn on the power. You will get the CMOS Checksum Bad error once more, but it should be the last time. Go into the BIOS setup and set the date and time, and any other options you prefer.<br /> <br /> <br /> Hope this will help...Your response is very much appreciated...
on Jan 24, 2011 | Computers & Internet
Tip
CMOS Checksum error
Issue:
Cause:
* BIOS update.
Workaround 1:
Note: If this issue continues to occur after you turn off your computer off it is possible that the CMOS battery may be failing or already bad. Before considering replacing the CMOS battery try leaving your computer on for several days.
Workaround 2:
on May 30, 2010 | Computers & Internet
How do I replace a y510 cmos battery
Locate your CMOS battery
Caution: When inside your computer make sure you're aware of ESD and all it's potential dangers.
cmos.jpgOpen the computer case and find the battery on the computermotherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in locating it.
Obtain battery information
Unfortunately, most manufacturers will not list the exact type and model of your CMOS battery; therefore, once you have located the battery, write down all information about the battery (Voltage, chemistry, wiring, and packaging). If possible, remove the battery and take it to the location you plan on purchasing a new battery from. The part number for this battery for most computers is CR2032.
Additional buying information can be found on our battery buying tips page.
Removing the battery
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Users with computers that do not have removable batteries only options to install a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Insert the new battery
Once you have purchased a new battery, remove the old battery (as instructed above) and replace it with the new battery.
Enter CMOS values
Once the battery is replaced turn on the computer and resetting the CMOS values to the defaults. After the values have all been entered make sure to save the settings before exiting. Many CMOS setups allow you to press a key (such as F10) to save values and exit all in one action.
If after following all the above steps you continue to experience the same error when your computer starts or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
Apr 19, 2012 | Lenovo IdeaPad Y510 Notebook
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
How to change cmos battery
cmos.gifOpen the computer case and find the battery on the computer motherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery you will need to refer to your motherboard or computer documentation and/or contact your computer manufacturer for additional assistance in locating it.
Caution: While in the computer make sure you're aware of Electro Static Discharge (ESD), your computer is off, and that you're properly grounding yourself. Especially before removing the battery.
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. Simply use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation and/or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Enter CMOS values
Once the battery is replaced turn on the computer and enter all values back into CMOS or set the values back to the default settings. Additional information about getting the values back to default can be found on document CH000970.
If after following all the above steps you continue to experience the same error when your computer starts and/or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
May 30, 2010 | Toshiba Satellite A60 Notebook
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Mar 05, 2010 | Microsoft Windows XP Professional With...
Acer extensa 4220 bios password
There's no way that we can determine the BIOS password of your laptop. But if you can disassemble your laptop and locate the CMOS battery you can remove the CMOS battery to reset the BIOS together with the password. After resetting the CMOS battery you will no longer be asked to enter a password for the BIOS when you turn on your computer. However, there are instances that even though you reset the CMOS it's still asking for the password, for this concern, the computer manufacturer should deal with this concern.
Jan 14, 2010 | Acer Computers & Internet
Always display bad cmos setup
have you checked the jumper next to the cmos battery? check if its good not broken and also try and upgrade your firmware. visit your motherboard's manafacture for the firmware upgrade.
Nov 13, 2008 | Asrock P4I45GV R5 Motherboard
CMOS battery replacement
Your Pc should have an Intel E210882 motherboard in it.
A coin-cell battery (CR2032) powers the real-time clock and CMOS memory. When the computer
is not plugged into a wall socket, the battery has an estimated life of three years. When the
computer is plugged in, the standby current from the power supply extends the life of the battery.
The clock is accurate to ± 13 minutes/year at 25 ºC with 3.3 VSB applied.
When the voltage drops below a certain level, the BIOS Setup program settings stored in CMOS
RAM (for example, the date and time) might not be accurate. Replace the battery with an
equivalent one. Figure 14 shows the location of the battery.
These batteries are very common and can be purchased at Wal-Mart, Walgreens, Etc...
Here is a link to the motherboard manual with battery replacement procedures:
http://www.asi.com.au/support/Drivers/V206/Manual/SR_English.pdf
Jan 04, 2008 | Computers & Internet
Dell Inspiron 530 Desktop Computer   Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
