Have no power. Power to socket but no lights on machine
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 14, 2015
No power to Miele W404 Plus washing machine.
hi
it could be faulty flex cable from the washer to wall socket or where the flex cable is screwed into the terminal block inside the machine come out or broken
Dec 21, 2017 | Miele Washing Machines
I purchased a refurbished GE MAC 1200 EKG machine with a new battery. The first time we used it, it worked perfectly. The second time we used it however, only the standby light comes on. The screen remains...
There's several things that could be wrong. What I would do would be to try to run it off the battery, and if it works, then there is a problem either with your power cord, the power cord connection, or the power module inside the machine itself. Try completely turning off the system. Unplug it, figure out a way to let the battery be disconnected, turned off, or just simply let it die. Then re-boot the device and see if there's a change in operability. If there is, or isn't, you should consult the owners manual, and see what you can find on the issues your having. If all else fails, have a technician stop by and work on it.
Nov 25, 2014 | Medical
Power socket dead
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 01, 2013 | Computers & Internet
No power to my Indesit Washing Machine.
PCB has suffered a catastrophic failure due to the power cut, it will need to be replaced. if you have a power cut in the future always turn off your appliances, as the voltage can exceed the appliance recommended voltage. only leave a light on as lights can take the over voltage unless they are led type, you can but power drop sockets that when power is off it turns of the socket off so no power goes thought to the appliance.
Feb 01, 2018 | Indesit W 123 Front Load Washer
I have a power problem. I have a p205-s6267....4 years old. I have several power problems that have evolved. My machine is intermittently charging. I changed the dc imput. It seemed to...
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Feb 22, 2011 | Computers & Internet
Gateway 500s power box when hitting test button powers both fans, but no power to hardrive, dvd, or monitor. I have replaced power supply, motherboard, and harddrive, I have nothing, but green power button...
Does the fan on the power supply run? As you say the power on switch lights up and so does the motherboard, means that the power supply is working. Monitor gets power from the socket on the power supply. Try plugging it in the wall socket. Try to unplug the main power cord from power supply to the motherboard. The one that has a broad plug at the motherboard end. Replug it and they power on the PC.
Sep 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
No power or recharge light is there a fuse inside from wall to laptop tested 18.5 volts coming out but cant turn on recharge
Hi,If there power out from the ac power pack then the next area to check will be the socket going in to the machines,this leads me to the next point,
try removing the battery ,plug in the ac power pack,
if no result then it will be either the mother board or power socket,
sometimes cheaper to replace it unless you know what your doing,
Apr 30, 2010 | Computers & Internet
Hoover visionhd no power
Check wall socket , Check machine door interlock switch, you may need multimeter to do further checks....
Oct 04, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
