Question about GE / Caddx Networx Programmable LCD Keypad NX148E
GE NX148 alarm goes off every day in a different location. No windows open or anything. Thought it was sensors but now I'm thinking alarm panel or other equipment.
  • GE Master
  • 15,557 Answers
IF this is a wireless unit then it may be receiving stray interference.
Posted on May 13, 2015
3 Suggested Answers
ford_67
  • 34 Answers
SOURCE: GE Simon Security System - help!!
The default for option 10 is 30 seconds and option 11 is 60 seconds.
It sounds like option 10 is turned off because when turned off the entry delay is set to 005 seconds. All entries must be 3 digits.
You ca set option 10 and 11 from 005-254 seconds. Hope this helps
Posted on Aug 24, 2008
  • 74 Answers
SOURCE: Having problems programming the door sensors on a
It sound like you are programming the sensors as a 24 hour zone. They need to be either a type 10 (entry exit) or type 11 perimeter.
Alarmprofessor.net
Posted on Sep 05, 2010
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
I have a GE Simon Security System with a GE Simon 3- X10 Line Carrier Transformer that powers a siren. Since the X10 transformer was installed, I constantly get sensor 'failures.' Although the panel...
X10 is a signal format transmitted over the power lines, there is no special X10 wiring in the house as such. The siren and your outside lights are X10 receivers which are sent a signal from the X10 transformer connected to the alarm panel. The alarm panel sends the codes which are transmitted as X10 to the X10 external devices. Most houses now days have at least two 120 volt feeds coming into the main power panel, this provides the 240 volt required for electric stoves and dryers. Because of the two separate feeds split at the panel, the 60 cycles is usually out of phase with each other. To get X10 to work and stay in phase on each side of the panel you need to have wired a passive coupler across both 120 volt inputs. This coupler keeps both 120 inputs in phase with each other and provides a clear X10 transmit across the house wiring.
Dec 19, 2010 | GE Security Simon 3 Wireless Home Security...
How do i change the panel voice feedback on GE Simon 3 to say something different? For instance, instead of it saying "East Bedroom Window Open", can I change it to say "Blue Room Window Open"? I have 5...
Unfortunately the Simon 3 has a limited vocabulary. The alarm company probably did the best they could. It will tell you the zone number 1-24 but you may already have the best audio descritption you are going to get.
AlarmProfessor.net
Apr 07, 2010 | GE Security Simon 3 Wireless Home Security...
Beeping at random times through the day
You are getting trouble beeps, every time you press status you delay the alarms for 4 hours then they begin again and beep every minute. You need to run a sensor test to find out which sensor has a problem. Open the panel, enter your code and press the test button, it will begin scrolling through the sensors. Activate each sensor until it stops, if one doesnt work it will keep asking you to activaate it. You probably have a dead battery in a sensor.
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
'95 Nissan Maxima-Alarm goes off-then windows & doors won't work
Open the drivers door panel and locate the inside lock cylinder, there is an alarm switch that wrap around it with an electrical wire came out, it might also have another one on the passenger side in some other model . What it does is arm and disarm the alarm when you use the mechanical key and in some other model, it also lower the window when you disarm. The switch might pop out of place or deteriorated due to age. Good luck all.
Mar 22, 2017 | 1995 Nissan Maxima
Problem arming all sensors on ge simon security
I have yet to test it but I think I've figured it out... I spoke to the place I bought the alarm from and he stated that for both the door/windows & motion to arm, you have to leave the house (or activate an exit door) or the alarm thinks you are still in the house. Since the motion is instant on, this prevents you from accidentally setting off the alarm if you armed it and never left.
So what if you want to arm both and stay inside? There is an option called Unvacted premises (in the Timers menu). It's on by default and makes the alarm behave as described above. Set this option to off and you should be able to set both and not leave the house.
James
Feb 03, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 Add or Change a Sensor to my system?
You need to use an installer code to add/remove sensors. Depending on what number of digits your alarm code is set for will determine the number for the intaller code. Look in the installer manual for the code. Then follow these steps:
Open the panel.
Key in installer coe
Select Add
Select Sensor/Remote
Activate the sensor you want to add. Some sensors have a button, some have to opened to activate.
Choose sensor name and group. Groups are listed in the manual. Basically, if you want the sensor to arm when the doors arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
Oct 06, 2008 | GE Security Simon 3 Wireless Home Security...
Manufacturerscar alarm
My alarm is triggered when I leave the windows down a bit. There's a motion sensor for the interior of the car (I think it's thermal), so when a breeze blows cool outside air through the car's hot interior, it triggers. The interior sensor can be turned off by pressing the button just behind the driver's door and in front of the rear door. Try turning that off and see if it makes a difference. Post a comment with the results.
Jul 01, 2008 | 1999 Audi A4
GE / Caddx Networx Programmable LCD Keypad   NX148E Logo
153 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Electro Med Services...
Are you a GE Home Security Expert? Answer questions, earn points and help others
