Question about Eureka Vacuums
Clean a vacuum.
The suction is quite weak now. Is there more than that foam filter to deal with?
  • Eureka Master
  • 1,493 Answers
Almost all vacuums have more than one filter.
Posted on Apr 07, 2015
LizDahl
  • 75 Answers
SOURCE: Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Posted on Jan 28, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell Lift Off pet revolution vacuum losing suction
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
Posted on Mar 20, 2008
reddevil6
  • 1673 Answers
SOURCE: my eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Posted on Jun 17, 2008
chris321918
  • 32 Answers
SOURCE: vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Posted on Jan 19, 2009
galati2k
  • 281 Answers
SOURCE: suction problem
check the intake hose at the bottom it may be clogged.try blowing into the long hose if you can't blow through it then you have a clog somewhere between the long hose and your intake hose at the bottom.the intake hose is the somewhat clear hose that comes up from behind the base at the bottom.you will see it on the backside
Posted on Apr 04, 2009
Hepa 100 dont seem to work it has a muffrer round thinghow do you no if its on
Not sure what you are referring to--if no suction or weak check for blockages from head to air filter--also look to see if filter clear and clean, foam ones can usually be removed and washed and paper ones have to be replaced.
Nov 06, 2012 | Vacuums
Uv200 very weak suction
is there a blockage in the inlet pipe ???
Jul 12, 2012 | Black & Decker UV200 Wet/Dry Vacuum
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Wertheim vacuum cleaner 2000 does not seem to be having enough suction
If you are sure the is no leaks on suction line, please check and clean the filter. The common problem on weak suction vacuum cleaner are leaks and filter clog up.
Regards
Jun 18, 2011 | Vacuums
My vacuum tools have very weak suction.
There is a foam ring filter in the bottom of the canister that collects the dirt. It screws off of the bottom on the canister. Take outside and shake it out. It fixed our suction problem.
Jan 31, 2010 | Bissell 3576 CleanView II Bagless Upright...
Dyson vacuum suction loss
clean it out
check all the filters
I think it has a foam filter as well as the filterless design
clean and lubricate the motor
make sure it is not leaking and sucking in air from somewhere else
Jan 02, 2010 | Dyson DC11 All Floors Bagless Canister...
Very little suction in hose no tears in hose
Hi there, SmartAlec from NelsonVacuums.com.au . I have fixed hundreds of Dyson DC07 vacuum cleaners over the last few years and i would say there are 2 possible causes for the loss of suction.
1st is that the filter looks clean but is actually worn anyway. The way to tell is remove the washable filter from your vacuum cleaner. Take out the foam insert this seems to last longer that the other part. Hold up the plastic cage to the light and look at the white part (well it used to be white anyway) you should be able to see light through it. If you cant see through it you need to replace it. Here is a link to that filter for purchase . To verify this is the problem just run the vacuum without the filter in you should see an improvement - note do not actually **** up material the filter is there for a good reason.
2nd problem is that you have a blockage in your radix assembly. If you take off the whole dirt bin and feel the suction on the upright part where the chamber joins the vacuum (basically bypassing the radix) if there is good suction here you will either need to replace the cyclone top or dismantle and clean it. (it is very difficult to clean as it doesn't completely dissassemble)
Hope this helps - If you want more help send me a message
HAPPY VACUUMING ! :)
Aug 24, 2009 | Dyson Vacuums
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
53 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
