Question about Cfm Heating & Cooling
How do I convert the CFM output to tonnage? Thanks much!
    Genius:
  • Cfm Master
  • 1,363 Answers
The old rule of thumb is you need 400 cfm's per ton.
Posted on Aug 07, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
CFM is air flow, a product of fan size and speed and duct size, opening sizes etc.. The tonnage of the unit has no bearing on airflow.
Posted on Apr 07, 2015
LRA 55.0 convert to TON
LRA is locked rotor amperage. Has nothing to do with Tonnage. Also Tonnage is not used anymore. The rating is now called SEER
Jun 02, 2016 | Heating & Cooling
Convert scfm to cfm? my compressor puts out 4.9 scfm at 90psi; 7 scfm at 40 psi so how many cfm at 23 psi?
Hard to give an exact number, however, as pressure and temp of air increases, the scfm drops as you see in your numbers. With low pressure such as 0 thru 25 the temp of the air is also low/nominal thus the scfm will be very close to the actual cfm listed for the compressor pump.
Feb 21, 2015 | Psi Air Tools & Compressors
Payne air handler with possible GE X13 Failure
Check your dip switch settings on tonnage and your CFM per ton settings. Also make sure they wired the the low voltage for cooling to Y and not YLO if its a single stage compressor system.
Sep 23, 2012 | GE Carrier Bryant Payne 1/2 Hp 115 230v...
Where is the headphone socket on a LT24M3
This is a link to the manual.http://www.haier.com/admin/en/product/upload/LT24M3-UM.pdf
On P.08 it shows the input and outputs. This television does not have a headphone jack. It has a digital audio output which is the SPDIF output.
To use headphones with the television you would need to get a digital to analog converter. Something similar to what is shown here: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=180-998
You would also need a digital audio cable (SPDIF cable). They are about $15-$30 depending on where you get it and the brand.
You would connect the SPDIF cable to the television output and the digital to analog converter box (DAC), and connect the headphones to the DAC box.
Feb 14, 2011 | Televison & Video
What is and how is find out cfm for 5ton air conditioner
12000 BTU is 1 ton
300 - 350 CFM in 1 ton depends on mfg.
Cfm and Tonnage of Refrigerent is are different units, then how these two units can be compared
Cfm means air flow per cubic meter per hour.
Dec 14, 2010 | Cfm Daikin R410a Split System Air...
I have a Goodman CPLJ24-1B condenser unit & am needing to know what tonnage it is guessing 2 tons? Would this be big enough for 2000 sq ft of floor space? Block building with no wall insulation.
Yes, it is a 2ton unit and no, it's definitely not big enough. You need 1 cfm per square foot. That's 2000 cfm. 1 ton of air is equal to 400cfm. So you would actually need around a 5 ton unit to comfortably do a 2000sq ft building. Insulation, doors, windows, and other sources of heat load all factor in, but this is the standard formula. Hope this helps!
Jun 19, 2010 | Goodman CPLE24-1 Air Conditioner
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Jan 08, 2010 | Goodman CKL60AR60 Air Conditioner
How to determine tonnage on a unit
generally 12,000 btu output is one ton, 24,000 is two tons, etc.
Aug 23, 2009 | Heating & Cooling
Need to verify tonnage of unit
In almost every case, most manufacturers put the tonnage in the model number. Look for something that is divisible by either 6 or 12. Something like, 24, 30, 36, and so on. Cfm has to match the tonnage. Usually in the neighborhood of 450 cfm per 12,000 btu's of cooling for the inside of the structure.
Hope this helps.
May 08, 2009 | Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
