Question about Toshiba Computers & Internet
How d I open cd draw - Toshiba Computers & Internet
    Top Expert:
  • Toshiba Master
  • 75,822 Answers
Pry it open or if there is a pin hole in the front insert a paper clip and push in.
Posted on Apr 01, 2015
My CD Player Draw Will Not Open
If there is a co in it then it probably fell out and is stuck... especially if it was shaken.... unplug the unit.... remove the screws holding the case together and open it up
Oct 16, 2014 | Electro Brand Nostalgic Stereo CD Music...
Cd drive xhnge
On the front of the CD rom there is a small pin-size hole, carefully put a drawing pin into the hole and it will open the CD drive manually, if it doesn't read disks anymore consider replacing your CD drive
Apr 17, 2014 | MSI Computers & Internet
How do I load a cd? when I open door cd just sits on top...is that ok?
Open the CD draw all the way and a CD/DVD should be pressed gently over the centre spindle until it clicks lightly. Then close the CD draw until it clicks shut. That's it..
Sep 06, 2013 | Acer Aspire V5-571P 15.6-Inch Laptop -...
THE CD DRAW WILL NOT OPEN CLOSE
IF YOU LOOK AT YOUR CD PLAYER YOU WILL SEE A PIN HOLE
PUSH A PIN IN AND THE DRAW SHOULD OPEN HOPE THIS HELP
Oct 05, 2012 | Audio Players & Recorders
Disc draw wont open
On the front of the CD tray you will see a small pin hole, take a pin or fine screwdriver and insert it until you hear click, the loading bay should pop open and pull out. Take a can of compressed air and blow inside to remove any dirt that may linger.
Mar 14, 2012 | Acer Aspire AS5334-2153 Notebook PC
My NAD cd-player has locked it self! I cannot play the cd's or even open to take the cd out. What can I do? Marit
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Nov 12, 2009 | NAD C521 CD Player
I have a dimensionsC521 that has swallowed my cd disc. It is an awkward cd slide since the cd does not stand upright and so I usually tilt the tower over so it doesn't slip out. Now it slipped out and the...
I suspect this is more a mechanical problem than a power or software problem
I suggest powering down your PC,
Laying it down so the CD draw is flat,
Fashioning yourself a home made cd draw ejector device (otherwise known as a straightened paper clip),
Pressing the paper clip quite firmly into the tiny hole next to the CD Draw (it should unlock and open slightly)
Carefully and gently pulling the CD Draw out just enough to see inside and find out where the disc has got to
Physically maneouvering your whole PC to get the disc back onto the tray where it should be
Then you can either manually pull the CD Draw out and remove the disc or start the PC while it's laid down flat and see if the CD Drive auto closes and begins to spin now the disc is properly seated
If your PC doesn't have the tiny hole on the front of the Drive or if the CD Disc cannot be seen at all or cannot be persuaded back onto the tray then it's time to start opening up your PC case and removing the CD Drive for more attention
- NOTE if your PC is still under warranty Opening the Case may invalidate that warranty, check this before you proceed -
Treat Everything Gently and Good Luck!
Sep 16, 2009 | Dell Dimension C521 PC Desktop
DVD draw sticking
sounds like the gears are worn!! next time you get it open look underneath and you will see some round gears. put some vaseline on them, not too much and open and close the drawer a number of times to work the grease in. all equipment needs lubrication of some sort !!
Dec 24, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
