Question about Dryers
How can this be a wiring problem if the dryer has been working fine for 2 years?
  • robert Apr 01, 2015
    what is ur issue?
  • Dryers Master
  • 2,374 Answers
What is ur issue. and make/model
Posted on Apr 02, 2015
Dryer wont start
I have a Maytag dryer 5600tq0 and my wife had it for 5 years. it stopped turning on. i did a trick by opening the back and locating the small white thermofuse (Part# 3392519), unhook the 2 wires attached and somehow stick a small wire to connect those 2 purple wires together. Then plug the dryer on and if it turns on, then that ThermoFuse is blown. I ordered the ThermoFuse Part# 3392519 from Appliance Parts Stop on Amazon $3.37. I also ordered the small silver n black (with 2 blue wires n 2 thick red wires attached)Thermostat part# 3387134 $5.00 from ACS on Amazon because it works together with the thermofuse and all websites say it is common practice TO CHANGE this also. then plugged everything back and it worked.
Feb 17, 2013 | Dryers
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
I have a roper dryer red4440sq0 that will not turn on.. I have checked all power its going to the dryer and hitting what it needs to hit and suggestions?
I bought this dryer 2 years ago. After exactly 1 year, the heat stopped working completely. It turned out to be the Thermal Cutoff device ($20). Then, just last week, the thing stopped working completely. It took me all of 10 minutes to determine that it was the Thermal Fuse (http://www.appliancepartspros.com/part_details.aspx?part_id=3132867), just by using my continuity detector on the two terminals. I unhooked the terminal wires, stuck them together, and the dryer turned on fine. They count on people buying new dryers completely whenever one of these dinky little parts made by child laborers in Asia fail. The fuse is $10 at the site I just linked.
Nov 09, 2009 | Dryers
LG Dryer Sensor
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again
Sep 27, 2009 | LG DLE2514 Electric Dryer
Our dryer is working fine until it trips the switch.
If tripping of the switch means the circuit breaker is tripping, then yes, the problem may be in the heater box, or may be the motor. It could also be some faulty wiring though, and a good tech could easily determine what is causing the failures.
Jan 24, 2009 | Roper REX4634KQ Electric Dryer
Dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
Jan 04, 2009 | Kenmore 64992 Electric Dryer
Dryer flips breaker everytime
There is a short to ground somewhere.
Most likely where any wires go through the cabinet into the door or inside the door where a hinge or other moving part ir rubbing it.
Disconect power (unplug it) and inspect all wiring close to those areas for worn spots. If you have an OHM meter, you can ohm each wire to ground and see which one is shorted, then trace it back to the problem area.
Dec 30, 2008 | Whirlpool WED5800S Electric Dryer
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
Maytag dryer
you are correct. have an electrician inspect the house wiring, especially for HIPOT test for insulation and shorting test.
Sep 16, 2007 | Maytag Neptune MDE6700A Electric Dryer
Hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Aug 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
60 people viewed this question
Top Dryers Experts
