Question about Performance Plus Carts 2006 Club Car Precedent Golf Cart - Black
How do i adjust gas pedal on an electric 2006 club car
2006 Lincoln ls when starting in cold weather, engine shakes, gas pedal won't give it anymore gas,is it normal for gas pedal not giving more gas while warming up?
No not at all , your vehicle has electronic throttle control . There is no cable connecting the gas pedal to the throttle plate. This system is all computer controlled .With all the sensors on the vehicle an the computer you need special tools to diagnose the system . Your best bet is to take it to a ASE certified repair shop or the dealer .
Jan 20, 2016 | 2006 Lincoln LS
Wont start car, display said start when 'P'. But it already on " P ".
Check and adjust or replace neutral safety switch that should cure your problem.
May 03, 2015 | 2006 Toyota Highlander Hybrid
2006 cadillac cts accelerator pedal sensor location
On the gas pedal assy
Not the problem
Move on to other issues
Need a scan tool to check modules
Aug 25, 2014 | 2006 Cadillac CTS
Adjusting cable throttle
loosen the screw or pull it to deired length and reapply it
Nov 04, 2013 | 1997 Dodge Ram 1500 Club Cab
Lincoln navigator adjustable pedal height wrong
Lincoln Dealers used to have an excellent rep helping Lincoln People!! As a next resort...visit your local Lincoln Service Writer...I would be surprised of any expense...These adjustments used to be reviewed with new buyers at time of delivery!! Lincoln Pride!!
Feb 07, 2013 | 2006 Lincoln Navigator
Club cart doesn't always start
This is not really a car question, but you are probably right on your hunch. There should be a switch under the floor that is connected to the gas pedal. There may also be a switch in the linkage where it makes contact with the engine.
Jul 26, 2012 | Cars & Trucks
I have a 2006 BMW 750li, removal of gas pedal
IF YOU ARE GETTING A THROTTLE PEDAL POSITION SENSOR FAULT CODE.THE THROTTLE POSITION SENSOR IS THE WHOLE THROTTLE BODY UNIT IS THE THROTTLE POSITION SENSOR.THE SENSOR NOT IN GAS PEDAL LIKE VOLKSWAGON. VOLKSWAGON HAS THE ACCELERATOR PEDAL POSITION SENSOR.
May 16, 2010 | 2006 BMW 750Li
Club car on off switch gets no power
This is a gas or electric 48 v or 36 v? what year model? F/R switch is a lever or a rocker arm? Club cars have made many changes over the years.
Sep 01, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Performance Plus Carts 2006 Club Car Precedent Golf Cart - Black Logo
254 people viewed this question
Top Performance Plus Carts Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Performance Plus Carts Golf Expert? Answer questions, earn points and help others
