Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
My Toro won't go in reverse on the left side.
    New Friend:
  • 53 Answers
Is the unit new? I saw a situation where Lowe's forgot to attach the steering arm. Then again, your pressure release valve (what allows for free manual movement) may be open.
Posted on Oct 17, 2016
2 Suggested Answers
  • 430 Answers
SOURCE: Slow speed on one side.
Check to be sure there is not a lot of grass and debris packed in spaces that prevent proper movement of the control arms.
If the control arms have free range of motion then you will need to check your fluid level and purge the pumps.
To purge the pumps jack the unit up and place on jack stands so that the drive wheels are off the ground. Release the transmissions so that they are in freewheel. Start the unit, release the brake and work the control levers slowly to full forward then full reverse 6 times. Shut the motor off, lock the transmissions back into drive. Start the unit and work the control levers back and forth 6 times again. Take down off the jacks and check fluid level. If there were any air pockets in the pumps this procedure would have purged the air out.
Posted on Oct 01, 2012
Toro Timecutter MX5050 74770 won't move forward or reverse.
find a breakdown of the parts diagram. that may help.
Sep 25, 2016 | Toro Garden
Why won't my Toro aero turn
First, make sure the steer stick in moving the lever into reverse. Please check this with the engine off
Second, Check the belt tensioner. Sometimes they end up stuck which has been known to cause the belt to slip on the left transaxle only.
Third, buy a new transaxle...
Next time, include model number for a more precise answer
Apr 01, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Oct 01, 2012 | Toro Garden
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
Tororider1338hxl how do I adjust the forward and reverse pedal it goes forward but not backwards verywell
Adjustment for this machine is made with the machine in the air. There is a cam nut on the right side of the transmission that can be adjusted to give more forward or reverse. Do this while in the air to make sure the machine does not creep away during adjustment.
see a local dealer like www.arcolawn.com for more tips and parts.
Mar 19, 2011 | Toro Lawn Mower With Toro Power Tools
I have replaced the transmission assy. on my toro selfpropelled; the problem I have is I can only get one side to work at a time. With no wheels installed, both of the gears on the front drive spin in the...
Many TORO mowers have a drive pinion that can be used on either side, however, internally, they ratchet one direction, drive the other direction. You may want to rotate (reverse) the installation of one gear and try it.
Nov 08, 2009 | Toro Lawn Mower With Toro Power Tools
How to adjust the carb on Mod. 206220 Toro
4 cycle is 1-1/2 turns 2 cycle high side which is the left screw is 1 to 1-1/2 & the low side should be 3/4 of a turn
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
314 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
