Sound output is scratchy and distorted. Changing speakers doesn't change anything.
  • 1,214 Answers
Good afternoon
  • go to tools on the computer and find
  • sound there
  • ajjust sound
  • to make it clearer
Posted on Apr 01, 2015
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
Aiwa subwoofer TS-WM6 has unclean scratchy sound but pot is OK.. Sound is like when a radio station is not tuned in. Faulty capacitor??
Maybe it's the amplifier board itself causing damage, it might need to be repaired by a professional or the manufacturer that owns the product. If not, you can try to troubleshoot the unit to see what's wrong.
May 12, 2017 | Aiwa TSWM6 Subwoofer
On low volume using the clean channel the sound is great but as soon as you get to about three or more the sound gets a bit distorted,the amp is the fender hot rod deluxe, ithort i may had blown the...
try a differrent speaker of suitable wattage and ohmage (displayed with a number next to a ? symbol on the back of the speaker),
or
remove the original amp speaker and gently push in and out on it, checking for uneven resistance or scratching. the speaker should retract and return smoothly, without any scratchiness or uneven resistance from within, and if there is any of this scratchiness or uneven resistance from within, the speaker is likely damaged from too much wattage or distortion.
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
Scratchy sound from cd/dvd combo
sounds like the speakers are either damaged or have gotten water in them and damage the laptop speakers.
Mar 29, 2009 | HP Pavilion Media Center M1090n (PC100A)...
Sound is distorted
Good Day;
Suspect the audio output IC. If you are using the TV's speakers.
Good Luck, big IRISH.
Aug 22, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Laptop sound distort / scratchy
have you tried connect external speakers and see what happens ?
Mar 30, 2008 | Sony VAIO VGN-N130G/W Notebook
Scratchy and Distorted sound
hi, first check the speakers if they r bad, u can do this by connecting external headphones, if it still sounds the same, then the probs is with ur sound card, uninstall it and install it back, let me know
Jan 14, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
