Question about Refrigerators
The coils in the refrigerator keep icing up. I defrost it with a hair dryer and they freeze up again in a day or so.
  • 52 Answers
Defrost timer might not be defrosting evaporator or you could be low on refrigerant, if so call refrigeration tech.
Posted on Apr 02, 2015
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Motor runs continuaslly and freezer is not freezing also ice is building up on coils
You probally have a failure with the defrost circuit. Its function is to periodically defrost the coils. Typical failures are the defrost heater, thermostat and timer if used with this model. Take a hair dryer to the coil to melt the ice, then check with a meter if the defrost heater needs to be replaced.
Aug 23, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
The freezer keeps freezing the coil in the back of the freezer how do I put it on defrost
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Take care....
Aug 15, 2010 | Roper Refrigerators
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Apr 25, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Coils freezing over evaporator fan working refrigerator hot compressor not running. melted ice with hair dryer freezer working ref working. what problem will happen in future
I would be checking the defrost element is not open circuit. Defrost element is the black tube under the evap. From fully defrosted they will run for a week or so B4 you'll notice the fridge warming again.
Apr 22, 2010 | Kenmore 57029 Side by Side Refrigerator
My refrigerator is not cooling, and the freezer is not defrosting. I'm getting ice build up in freezer and not cool air in the refrigerator portion.
That is a defrost problem. Either one of three parts are bad. Defrost heater, timer, bi metal. You'll need a part to fix this issue but you can take a hair dryer over the coils in the back of the unit where the ice has built up and continually move the hair dryer to defrost down the ice. But you have to make sure that the coils don't get hot or you'll hurt your unit. But this will make your unit work again for a few days until you can get a repairman or the part to fix it. This will not solve the issue but it will help you out so that you won't lose all of your food.
Aug 12, 2009 | Refrigerators
My Model ED5HHAXVQO2 REFRIGERATOR IS NOT COOLING. THE FREEZER IS NOT FREEZING BUT IT SEEMS TO BE BUILDING UP FROST.
Sounds like your auto defrost is not running long enough to melt the ice that develops on the coils. You can easily fix this problem by using a hair dryer and removing the back panel in the freezing unit to reveal the coils. Once this panel is out use the hair dryer to melt the ice. Once the ice is cleared this should restore air flow across the coils. Hope this helps. Good luck.
Aug 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer freezing over
We have the same problem: We own a Fridgedare FRS26ZXH that's about 10 years old. We went to the following website: http://www.refrigerators.com/refrigeratortroubleshooting.aspx
and found a solution.
A refrigerator self-defrosts about four times a day. If a part of the self-defrosting system stops working, the refrigerator keeps cooling. This causes frost and ice to build up on the evaporator coils, which keeps air from the circulating fan, which in turn prevents the refrigerator from cooling properly. It sounds contradictory, but if there's ice building up in your freezer, your refrigerator probably isn't cold enough either. We could not see the coils in the back of the freezer compartment (should be shiny aluminum color). All we could see was ice build up over what might look like a vent.
We carefully blew warm air on these coils with a hair dryer until we could see the coils. Time will tell the cause of this problem if it happens again. It may be coincidence that the outside temp went into the teens and my 4 year old flipped off our house's heating system overnight, causing the issue.
If the problem is with the defrost system, it's either the defrost timer, defrost heater, or defrost thermostat.
Oct 13, 2008 | Frigidaire FRS26ZSG
Bottom not cold enough
did you remove the back freezer panel ? if not need to
is there a large anmount of frost on the coil behind the panel?
if there is thaw the coil with a hair dryer
if there is no frost on the coil you have a sealed system problem that will nee to be taken care of by a tech
if frost is on the coil you have a defrost heater defrost thermastat or defrost timer that is bad
May 17, 2008 | Kenmore 21.7 cu. ft. Top Mount...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
