Question about Health & Beauty
I have undone the casing but not sure what wire to cut scared in case I do more damage lol
I have managed to remove the horn beep but not the reversing one
    Problem Solver:
  • 9 Answers
The backup buzzer is optional. There is slit toe red switch on the circuit board were there might even be a label saying buzzer. Switch one. The other is for the diagnostics beeper.
Posted on Nov 28, 2015
  • 1,263 Answers
And the mobility scooter is ?
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jul 11, 2015
2 Suggested Answers
  • 18 Answers
SOURCE: How can I stop the beeping noise when going in reverse
the beeper also provides error codes so not a good idea to start cutting wires .this can be turned off if not required .
this is a 5 minuet job ,but need to be done by a mobility center
who will plug a pp1a/b penny and giles programmer into the 4 pin plug from the sdrive controller select the beep and turn it off ,there is no other way of doing this correctly
Posted on Apr 09, 2015
Horn does not hoot
Have someone listen under the hood for the sound of a clicking relay as someone actuates the horn ring. Remember if the horn does blow you might scare the listener!!!
If no click check for the under hood relay. If relay not activating check the horn ring. Some times adjacent relays have same pin out/part number. Swap relay and try. Many of the cars use a "clock spring" design on the wheel. Problem air bag circuit makes it difficult to service. Check to make sure all other services are working attached to the wheel (Speed control, radio,etc). If clock spring is failing eventually other circuits would be affected.
If you have key-less entry and have a horn beep confirmation try the FOB. No beep than maybe horn clock spring OK! In no horn beep confirmation try the panic on the FOB. That should make a little noise, and if nothing else you can check your lights.
Ck the fuse if OK
Hot wire horn if still no horn
Replace Horn
Dec 03, 2015 | Peugeot 308 Cars & Trucks
Removed the only wire connected to horn it now is only held and connected to frame by a single bolt. Afraid to wire in air horn because horn still sounds even though it has no wire connected to it.
Hi Christian:
Many vehicles have 2 horns so that the sound is more pleasant. If there is no wire connected to a horn, it can not (in my experience) make any sound. May I suggest that you have someone assist you by tapping the horn button while you locate the horn that is sounding.
Sep 16, 2015 | 2000 Isuzu VehiCROSS
I am an insurance adjuster handling a claim involving stolen property from this jeep after parked by a valet. It has a Sentry key theft system which was activated by valet.
sure, cuts horn wire and alarm horn.
s.o.p. most thief.
im the poor sod fixes this damage../.
the valet key allows just that. drive car and park it no alarms.
but breaking any car is easy for any pro to avg, thief.
to steal items in car,,
are you saying owner left a key in car?
a key fact . LOL
Aug 17, 2015 | 2015 Jeep Patriot
Horn is working sporadically. Now it does and now it doesn't. If it's grounding problem, will cleaning the Unions with WD-40 fix it?
You need to take the horns off and spray the connector terminals with electrical contact cleaner. Make sure an ground wire; common between two horns usually, don't have corrosion on them. Remove any nuts and use crocus cloth to remove it by light sanding motion. Re-attach everything. If the horns work okay, then apply some WD-40 to the bolted ground connection to prevent future corrosion. In some cases, the horn driver may be blown, so you may need new ones. Get them from a junkyard, this aids in recycling.
Mar 21, 2015 | 2000 Toyota Sienna
2003 acura tl horn does not work when pressed but alarm horn works
If the alarm horn is the same unit used as the car horn then your problem is the contacts for when the horn is pressed. Some horns are activated by pressing the large center area of the steering wheel others have little buttons on the left and right side of the steering wheel. If the latter is the case make sure you try both pressure buttons to see if horn will work. Either way the contacts have to be cleaned or the wheel needs to be adjusted to allow the contacts to touch each other when pressed. That's most likely your problem.
May 17, 2014 | 1998 Dodge Caravan
Hi i have a 96 gsx600f it had an air leak but fixed it to some extent. I adjusted the air/fuel screws a bit an u had to rev it slow to build the revs up, once it hit bout 5k revs the throttel responce...
You pinched or routed the throttle cable wrong when you put it together. Take the tank back off and check it. Make sure you can hear the throttle plates closing when you release the throttle before you reassemble it.
Oct 25, 2013 | Motorcycles
C'ant open the case of my pc
Look in the back of the PC. there are often several easily accessible screws on the outside edge of the steel backing. Remove all the ones close to the edge and attempt to slide the side of the computer back, depending on the method they used to build it you should just have to pull back and up when it comes loose.
Mar 07, 2011 | Computers & Internet
My 03 gmc HD 2500 horn doesn't work but when I put
the wiring on the steering wheel hooked up to the horn may have come undone or even around the steering colum there are two screws on the bottom of the coloum you can remove to acces the wiring, check to see if you may have a chaffed wire or even a cut wire
Sep 23, 2009 | 2003 GMC Sierra
Horn doesn't work on 2007 Taurus
TRY TO UNPLUG THE HORN AND RUN A LIVE WIRE FROM THE BATTERY TO THE HORN JUST TO MAKE SURE IT DIDNT GO BAD IF IT DOESNT BEEP THEN REPLACE THE HORN IF IT DOES THEN CHECK IF THE FUSE IS IN PROPERLY JUST REMOVE IT AND PUT IT BACK IN.
Aug 21, 2009 | Pro-Fit Pro.Fit Fo 55 00 Ford...
Turning the beep off?
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. Step2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device. Step3Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels. Step4Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jan 11, 2009 | GE Profile DPXH46EA Electric Dryer
Health & Beauty Logo
145 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
