Question about Yamaha P95 Digital Piano
My yamaha p 95 .Only touch key (D-G-A)on Same time, will be more G # key Sound? What is the problem?
    New Friend:
I have this problem too and it got worsened over time. Have you found a solution yet ?
Posted on Feb 08, 2017
Fixing noisy keys. Can I do it? Or what should I do?
you cannot fix noisy keys...that's how your model is meant to sound
Nov 23, 2015 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Yamaha psr 295
Hi, This is probably due to worn rubber contacts. The sound is switched by pressing a key which in turns press a carbon contact on the PCB under the key. In time these wear out and need to be replaced.
Firstly open up the keyboard and locate the rubber contacts, check to see if each one is seated squarely, if they are not seat straight then this can create the problem you mention.
If all are OK then you will need to replace the strip which is causing a problem.
Spares are available from many sources including :
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=16049
Jul 20, 2013 | Yamaha PSR-295MS Portable 61-Key...
Key doesn't work properlyon yamaha p95 piano
take it back, its still under warranty. That means the key has a contact problem in the circuit. you have to take it all apart, clean it, check the contacts....probably lint. You can try vaccumming it and it might fix the problem. I bought one too and it wasnt good
May 07, 2012 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Yamaha PSR S900 keyboard failure, in touch response mode when I hold one key (G) and touch another the second key produces a sound that is full volume just as if the "touch response mode "...
That is NOT touch response, but velocity sensing. Each key has two contacts and one closes before the other to facilitate measuring the key velocity. In your case, it sounds like the key you are holding down has a bad disconnect diode in the key matrix and is holding the "first contact" signal true so the next key senses max closure speed. If you are not electronically adept, you need to take it in for servicing... however first tip the thing and vibrate it as some contamination MAY be shorting a line in the key matrix. Staples and paper clips are notorious problems with keyboards when they get into the key area.
Oct 31, 2010 | Yamaha Music
Yamaha Gran Touch problems
bit late. I have had the same problem. I replaced the optical module which solved the problem for me. The optical module is located above the keyboard and is used for scanning the keyboard.
Good luck,
F van Duijvenvoorde
Mar 12, 2010 | Yamaha Full-Size Keyboard
Yamaha psr 400 give an Er 1 message when switched on and gives no sound when played. The demo works however
Wild guess of possibilities.
1. Internal backup battery exhausted.
2. Button OR key is stuck down, either mechanically or electrically.
Jan 06, 2010 | Yamaha Portable Keyboard with 61...
Yamaha psr-240 lights up but no sound.. no sound from head phones either. Seems to be working with exception of sound out..
try placing your ear on the speakers, adjust the volume control up and down several times, you should hear a humming sound that goes up and down. if not problem with the stage before the amplifier, that is the sound processor. if you dont hear the hum. problem with the amplifier and speakers, including the sound ports or jack. dissassemble the unit. look for loose connections from speakers to amplifier.
Jul 14, 2009 | Yamaha Portable Keyboard with 61...
How to change speaker yamaha keybord
Simply put, the speakers can't be changed on Yamaha keyboards. If you have blown the speakers then put the sound through an amplifier or HIFI speaker system - but you must be able to have an AUX cable and AUX on the HIFI for this to work. Sometimes it can also work by use of composite cabling too, depends really on what audio equipment you have.
Apr 02, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Psr e303 yamaha double sounds
Do you cover the keyboard when not in use as small particles of dust can make their way in between the keys?
You can try blowing any obstruction out with a can of compressed air, may solve your problem.
As I'm not familiar with this Model, does the keyboard have 'touch response' on board? If so there will probably be a 'Contact' strip made out of tubular rubber under the keys and this can sometimes 'burst' especially on a certain key that is played most of the time. For example if you play mostly in the key of 'G' or keys that use that note....
Hope you find this helpful......
Dec 28, 2008 | Yamaha Full-Size Keyboard
Yamaha Keyboard PSR 730/630
no sound on all the g and gflats except the highest octave
Aug 04, 2008 | Yamaha Portable Keyboard with 61...
Yamaha P95 Digital Piano Logo
105 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
