Question about RCA Dta800b1 Digital-to-analog Converter Box
I got my new box but not the plug in cord, pam
How do I program a new parking assist module (PAM) on a 2007 Ford E250 van
You can't do this at home it requires special electronic equip that only the Ford dealer has..
Jul 12, 2012 | Ford E-250 Cars & Trucks
Tv was used as a computer screen, now I want to use a tv. Can't bring a menu up tv has been used a computer since new, now I'm wanting to us as a TV have sound, screen is dark has a very faint outline of...
What type of cable box are you using? Hope it's not the standard old school box. If you have an HDMI hook up, that should do the trick. Buy the cord and hook it up to your tv and box.
Mar 06, 2010 | Televison & Video
Keyboard locks up on restart from hiberate
Pam,
It seems it's the Power Scheme settings that you need check it out.
  1. Right click on the "battery/cord" icon from the task bar
  2. Choose Power Options
  3. On the Select Power Plan, check the Balanced option
Please come back if you still have the same problem, or if you have other problem.
Your rate on my solution is appreciated!!!!
Jan 06, 2009 | Lenovo 3000 Y410 Laptop
Power BOX supply cord problem or hardrive problem?
Check these settings first. In a clear spot on the screen where no icons are, right click and go to properties, box opens and at top should list from R to L, themes-desktop-screensaver-appearance-advanced. click on screensaver, close to bottom click on power, another box should open, click on power schemes, make sure it's set to portable/laptop, and at bottom make sure settings for plugged in are are set to never. If it's not that then you have a bad power supply cord, or a bad power supply unit in laptop. If it's new and under warranty take it in and have replaced if not warrantied then will cost you about 100-150, just a guess!! hope this helps. But it sounds like the supply cord making the beeping noise might be bad. Make sure it's plugged all the way in as well.
Nov 17, 2008 | Toshiba Satellite M40-S417TD Notebook
Not working
Mine comes on only when it feels like it...frustrating as hell!!!!
I have no clue whats wrong....i actually do know....i shouldn't have wasted my money on this hunk of ****
May 17, 2008 | Jazz DV-179 Digital Camera
360 No Longer Turns On
By cord, do you mean the entire AC convertor box? Does the orange light on the convertor box light up? If you used your friends whole ac wire/convertor box (w/ the plug that goes into the xbox itself) and THAT didn't work, then your motherboard took a surge. It is probably trashed as they are VERRRRRRRY sensitive and prone to failure. Time for a new one (or a warranty "repair").
Sep 12, 2007 | Microsoft Xbox 360 Console
RCA Dta800b1 Digital-to-analog Converter Box Logo
93 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
