Question about Home
Looking for shower and tub trim
Are there interchangeable parts from other makes to fit this faucet that is 35 years old
  • 659 Answers
SOURCE: Parts for sterling shower faucet
http://www.sterlingplumbing.com/contact.strl
The above link is the contact info for Sterling Plumbing Company. You can contact them and they will either be able to mail the parts out to you directly or tell you where you will be able to find repair parts.
Posted on Apr 17, 2009
  • 297 Answers
SOURCE: No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Posted on Jul 20, 2009
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
  • 102 Answers
SOURCE: I have a moen 1 knob push-pull faucet for my
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
Posted on May 14, 2010
  • 4348 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
I am trying to replace an old delta monitor 1300 diverter spout. It seems when I take off the spout it has a threaded part in the middle of copper pipe . The spout itself has a plasticinsert with threads....
Tub spouts are pretty much interchangeable although you may find the replacement spout cannot be installed easily because the threaded copper stub does not extend far enough to engage the threads inside the spout.
Nov 28, 2013 | Delta Faucet Delta T13422 13 Series...
LADBS Plumbing inspector says we need a temperature regulator for an In-Wall Lavatory Kit in a tub. The tub does not have a shower nor a wand? Which section of the code indicates this?
2010 International Plumbing Code
414.5 Limitation of Hot Water in Bathtubs and Whirlpool Bathtubs.
418.0 Shower and Tub-Shower Combination Control Valves.
Feb 28, 2013 | Newport Brass 1500 SERIES IN WALL LAVATORY...
Just got the tub faucet fixed from leaking now the water will not get hot in the shower how do I fix this problem?
If its a balanced pressure shower then you most likely have installed the cartridge wrong. Remove the trim plates and rotate cartridge 90 degrees clockwise and re-istall trim plates
May 22, 2010 | Delta Faucet Delta RP17453 Pull-Down...
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
How to change from a 2 handle plumbed in shower to a Moen One handle tub/shower trim
Moen makes a cover plate to fit over the 2 handle holes. I don't know the number off the top of my head but I have used alot of them. It alows you to cut a large enough hole to gain access to the old valve and replace it with a new single handle.
May 01, 2010 | Moen & One Handle Tub & Shower Faucet
Replaced trim ring and handle, now hot is cold ,cold is hot
Remove the handle and turn the stem of the cartridge 180 degrees then put your handle back on.
Apr 27, 2010 | Moen & One Handle Tub & Shower Faucet
Kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Jul 22, 2009 | Plumbing
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Feb 27, 2009 | Price Pfister 01-111 Shower Head, Tub...
Old Moen Valve Body
take a mesurement of tap head across then go to local hardware store and have a look around it might be better to change hole set . thank you for useing fixya please rate me
Feb 23, 2009 | Moen 2919 Chateau Two Handle Tub and...
Home Logo
47 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
