Question about Wizcom QuickLink Pen
The pen's screen is not legible - partial lines but no letters showing so i can't do nothing.
New battery
Nothing shows on scxreen after turn on, and new batteries
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Dec 14, 2013 | Texas Instruments TI-84 Plus Calculator
Nothing shows up on the screen when I push any buttons. It will turn on, but after that nothing I push shows up on the screen. I have taken the batteries and the back up battery out.
Does the cursor show up at all? TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 29, 2013 | Texas Instruments TI-84 Plus Silver...
My ti 83 calculator turns on but nothing shows
TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
May 20, 2010 | Texas Instruments TI-83 Plus Silver...
My 2gb pendrive not working it is not detected
Trouble:
You may have faced a problem when you insert your pen drive and it gets detected very easily but it doesn’t show up as a drive icon in My Computer. The Computer detects the pen drive but data on pen drive is not visible as the pen drive is not visible in My Computer (Explorer).
This problem occurs mainly when windows XP fails to allocate a drive letter to your portable drive(pen drive). It occurs mostly with new pen drives connected to your computer for the first time. If you face such problem then it may not be the pen drive’s fault, rather it may be windows trouble.
If Problem Fix:
Fix:
You can fix this issue by following some simple steps given below.
1. Click Start, click Run, type compmgmt.msc, and then click OK.
2. In the console tree, click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. Now a assign a new drive letter which is not being used by any of your drives in My Computer.
5. After assigning the new drive letter your portable drive will show up in my computer with other drives
Jan 29, 2010 | Transcend T.sonic 612 MP3 Player
Moultrie dig cam-digital screen on cam has lost partial letters
A known issue....contact moultrie (www.moultiefeeders.com)...they will send you new one free of charge; free shipping
Nov 26, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Won't work at all
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Jan 28, 2009 | Texas Instruments TI-84 Plus Calculator
I TOOK THE AA BATTERIES OUT OF MY Ti-84 CALCULATOR NOW I HAVE A BLANK SCREEN AND NOTHING SHOWS ON SCREEN. dID I BREAK IT/ i AM SCARED CAN SOMEONE HELP ME.
Jan 23, 2009 | Texas Instruments TI-84 Plus Calculator
Screen display not working properly
not a PERFECT solution, but it's a slight one
i have the same problem. i go through it everyday.
but when my phone does it. i either hold down the joystick, or the delete button, and it puts away the lines for a slight bit. be careful when sliding it down though, sliding it down hard can also cause the lines to show up.
Nov 13, 2008 | AT&T LG CU720 Cell Phone - Silver
Weird lines, characters, symbols etc.
It sounds like you need to put in a new set of back-up batteries. They can be found behind where the AA batteries are.
Aug 17, 2007 | Texas Instruments TI-83 Plus Calculator
Wizcom QuickLink Pen Logo
244 people viewed this question
Top Wizcom Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Wizcom Office Equipment and Supply Expert? Answer questions, earn points and help others
