Question about Wizcom QuickLink Pen Elite Handheld Scanner
When turn on,screen only shows lines and not letters..even if i put in the new battery.
Anything to do for vertical lines on screen?
most likely a damaged sensor. How about the pictures? Do they show these lines on them too?
Oct 23, 2015 | Canon PowerShot ELPH 340 HS Digital Camera...
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
Letter ''Y'' not working in keyboard
You might be attacked by a virus, so scan your PC with antivirus thoroughly. If it doesn't work, try my last powerful way. Follow me how:
Click Start Button>All Program>Accesories>Accesibilities>On Screen Keyboard. DONE!
If you find it unsatisfied, Try to Remove the OFFICE, and re-install it! GodLuck!
Jun 15, 2009 | Toshiba Replacement Keyboard
DYMO Labelwriter 400 prints very slowly and incomplete
put in new batteries. The ink is operated by heat, hence you will need to put in new batteries and this should solve your problemn
Jun 10, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
I put the battery in it shows no battery symbol on the screen
Hold in Alt, delete in backspace in immediately after putting the battery back in until you get the hour glass.
Apr 11, 2009 | RIM BlackBerry Pearl 8100
Screen shows battery with a red line through it
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
Thermostat won't stay on, even with new batteries on hunter therm
replace the thermoste with a new one its easy to do
1.turn of breaker to doorbell air handler and compresser (outsideunit)
2 take of thermostat lble wires as to wich leters they conect to
3 put on new thermostat enshuring whires are conected to corect letter
4 turn on beakers and enjoy!!
Jan 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
My Canon PowerShot A75 just started showing horizontal lines on the screen and the color is off. I just put new batteries in and made certain that the batteries were in correctly and the setting was on...
Click pictures and download and check if they have come out properly ...if the pictures have come out properly then there is a fault with your LCD Screen ..... And If the picture turn out to be having those lines ...then the CCd is faulty .....in both cases a repairman is recommended
Oct 14, 2008 | Cameras
Phone is not working
It is not worth to fix it.  I just got a new one.  Thanks!
Aug 07, 2008 | Olympia InfoGlobe Cordless Phone ol3020
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Wizcom QuickLink Pen Elite Handheld Scanner Logo
Top Wizcom Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Wizcom Office Equipment and Supply Expert? Answer questions, earn points and help others
