Question about Garden
First startup of the year. Engine runs fine but when I pull the trigger water pressure instantly goes to nothing but normal water pressure. What am i missing.. same house water pressure as last year.
    New Friend:
    Problem Solver:
  • 9 Answers
Have you check hydraulic fluid level in pump? Do you have the pressure washer tip in wand when trying if so tip could be clogged up.Also try starting up washer with pressure washer hoses disconnected see if water comes through pump if not then hoses could be clogged up. Had insect build nest in hoses and clogged them up now I hook hoses ends together when I store them. Also leave gun disconnected and see if water pressure comes through if so then gun is clogged up.
Posted on Apr 03, 2015
  • 2,527 Answers
Idon't know why I'M answering you .I read about these people who have powerwashers and its mostly the same all of the time so I don't answer them because I don't want to insulte them .
But I owen and use these mechines in my bisness all of the time replace packings mabey every 10 years or so have serivel mechines big and small some over 30 yr old .
.And then I read from people telling you to replace the pump that will solve the problem .
Well I'm going to give you the secret
If you don't put antifreeze into the system before you store it .Then expect problems
The best thing you can do at this point is get as much light oil into the system that you can spray it into the water intake WD40 TIP THE MECHINE ON ITS SIDE .Then pull the started cord slowly with the ignition off let it stay for a few minitues then do it again this will lubercate all of the rusted areas and hopefuly bring the dryed out water seals back to life and get it pumping again.
The other big issue is the unloader valve likely bound up with rust and reglect. This the knob that adjusts the pressure witch is a nominal feature on any mechine because every body wants the MAX pressure thinks thats the best .I will tell you different if you don't move this valve it won't work any more and you don't need the MAX all of the time
Good Luck I just have a problem with equiptment being distroyed because of lack of information read your oweners manaul bet it dosn't say what I did
  • 1,169 Answers
Pump check valve(s) or o-rings failure. Depending on the pump it might more cost effective to just replace the pump assembly.
Posted on Apr 01, 2015
Engine is running faster than normal & causing spray to come the wand without pulling trigger?
Trigger for wand needs replacing, water bypassing it and not allowing pressure build up enough to close pressure switch, allowing engine to go back in idle
Sep 16, 2015 | Garden
My pressure washer engine runs fine, but when I pull the trigger, it doesn't pressure up the water strean. I just get a slow trickle. I replaced the wand, and it worked OK for awhile, but now it has
you mainly have a water pressure problem you get air in the line and no water comes out mine does it a lot i just keep playing with it and it works
Aug 30, 2014 | Honda Garden
Troy-Bilt pressure washer does not provide pressure
Sounds like your pressure pump is shot. Replace it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Briggs & Stratton Garden
Troybilt pressure washer won't run
If you ran the pressure washer without water running through it on startup you probably got your pump.You are supposed to engage the trigger on start up with water running through it so as to release the pressure off the pump so it will start easier. Hope this might help you.
Sep 15, 2009 | Briggs & Stratton Prosumer 20324 Gas...
Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Aug 09, 2009 | Karcher 2500 PSI Pressure Washer
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Garden Logo
204 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
