Question about Starbucks Barista Burr Grinder
I have an el60 grinder..I was able to pry the plastic part of burr off but can't put it back on?
I am afraid i will break it if I put too much pressure on it
5 Suggested Answers
  • 1340 Answers
SOURCE: Our Starbucks Barista burr grinder
Here is a link about a person who had a similar issue.It doesn't answer your question yet but I am searching.When we were looking for a coffee maker last year,I think at BB&B they said that DeLonghi makes all Starbuck's coffee machines.We were disappointed with the DeLonghi.I am checking around to see who makes it though,and possibly an image so I can see better what you mentioned.Greg Will reply again when I find something more.
http://coffeegeek.com/reviews/grinders/starbucks_barista_grinder/Cafetiere
Posted on Dec 02, 2010
SOURCE: Starbucks EL60 coffee grinder: where
Did you find one? I need one also.
Posted on Aug 16, 2011
Sagar Tech
  • 107 Answers
SOURCE: I took my Starbucks Barista
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Posted on Aug 28, 2011
  • 44422 Answers
SOURCE: This is the part of my el60 Starbucks coffee grinder that I was able to pry out but can't get it back in. Any suggestions?
sure buy a new machine .
Posted on Apr 06, 2015
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Remove the inside conical burr
Hi
Try wrapping some leather, cardboard or cloth around the burr before putting the vice grips on and then it is a quick twist to break the burr loose.
Nov 28, 2009 | Solis Maestro Electric Burr Grinder
Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Grinder is slipping.
  1. take out bean container
  2. disassemble 3 philips screws and take plastic out
  3. rotate the knob to try to get out the upper holder of burr. if it does not rotate than disasemble the knob and the gears(plastic big one is attached to upper holder of grinder, the other is together with knob.
  4. tru to rotate it manualy, with help of extra srews puted in gear holder holes.
  5. when you get it out, carefuly clean it, look for metal parts and stones(wich sometime comes with coffee)
  1. turn on the grinder and attach gently one marker to lower burr during spining. after you stop grinder, look if it is perfect circle marked in burr. if it is not than marked side is higher. you should consider getting it ok by putting adhesive paper under lower burr and check it again.
good luck and carefuly.
Aug 02, 2008 | Gaggia MDF Coffee Grinder
Krups GVX2-12 Electric Burr - Thermal Fuse
Open the grinder by removing both knobs.
The front knob is held in place by friction. Use two flat head screwdrivers to pry it off.
The side knob is held in by tabs you have to push. Pry forward to expose the tab, and use another screwdriver to press the tab, and use the other screwdriver to press the tab on the other side.
Now look at the bottom of the grinder. There are four tabs on the outer shell, use screwdriver s to pry the tabs to separate the bottom of the grinder from the shell, and pull off the shell. Your fuse should be attached to the motor wiring coil.
Jan 01, 2008 | Krups GVX2-12 Electric Burr Grinder
Gaggia MDF Electric Burr Grinder
It could well be gummed up with years of coffee bean residue
Very simple to take apart. There are two screws holding the cannister. They are hidden under 5mm round rubber covers that you have to pry off. Then remove the two screws holding the plastic cover. Mark the position of the numbered dial relative to the brass burr assembly then remove it. Once exposed, you should be able to figure out why it is locked. Scrape away as much gunk as you can.
Aug 18, 2007 | Gaggia MDF Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
246 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
