Question about Jensales Kubota B7100hst-e Diesel 2wd Opt Fo Operators Opt Manu
Why does foot pedal stick in forward position?
When using the foot pedal for forward playback to transcribe, when you lift your foot to stop the tape continues forward for about a second.
It sounds to me that you might have a mechanical problem in the machine. I am not familiar with this machine, but I have worked on lots of tape machines. The belts and rubber pieces can get slick or stretched causing problems.
Oct 24, 2017 | Sony M-2000 Microcassette Transcriber
My Lawn Mower does not stop when I remove my foot from the forward direction foot pedal.
sticking check valve they probably messed it up try to bleed air out
Oct 02, 2014 | John Deere Garden
Clutch pedal sticks while in f/r.
brand/model number please... either a spring issue or a variable speed pulley issue
Aug 31, 2014 | Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
Random acceleration
throttle position sensor is bad
Aug 17, 2017 | 2000 Chevrolet Venture
Sticking gas pedal
its either the throttle cable is binding or you could just loosen the clamp off the rubber intake boot. and pull it off the intake and pull open the throttle and clean the butter fly that opens and closes and see if that helps, if its really dirty with old oil carbon build up itll feel really sticky. does this help
Apr 07, 2009 | 2001 Toyota Camry
Wispertone 116.29429990
That pedal is hard to break, use a large flat blade screw driver, stick it from the bottom and back of the pedal and pry up, it will pop off, watch for the spring, it may fly off.
Feb 22, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Jensales Kubota B7100hst-e Diesel 2wd Opt Fo Operators Opt Manu Logo
55 people viewed this question
Top Jensales Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jensales Garden Expert? Answer questions, earn points and help others
