Question about Garden
How to change from spring blade to solid blade?
    Top Expert:
  • 10,875 Answers
Unbolt the mulch blade and put a regular blade on it and tighten it,beware,if your deck was made to only mulch,you cannot use regular blades
Posted on Apr 01, 2015
The blade is stuck in my DW 310 saw. The spring loaded collar will not move as appears the blade is not in the two top grooves? Thoughts to fix? Thx!
Does the motor hum when you pull the trigger? If so, check that the push tab for securing the shaft from turning while changing the blade is pulled out all the way. Sometimes fine saw dust can get inside and prevent the spring from pushing the tab back out all the way. If there is no hum, check the power source.
Mar 22, 2017 | Blade Saws
How to change heiniger clipper blade support
No adjustment needed but you must make sure the spring ends from the hinge are pushed into the two holes either side on the latch. If your still having trouble give us a call.
http://www.angliaclipperservices.com/dog
Jun 03, 2016 | Heiniger Saphir Cordless Dog Clipper
How to fit compression spring on makita LS 1040 mitre saw
Go to: http://www.ereplacementparts.com/makita-ls1040-miter-saw-parts-c-97_98_99_323.html. They also have a video on how the replace the blade. Look closely at the parts diagram to see how and where the spring fits and fit accordingly.
Sep 09, 2014 | Saws
I have a craftsman GT3000 with a 48" deck. The blade belt was old so I thought I could replace the belt without removing the deck. Not a good idea. I unsprung the tension spring to remove the belt. Had...
Use a long pry bar the fits the s[ring end and lever the end against a solid part of the base, then stretch the spring and let it slide into the rtaining slot. The long bar is the key since it will multiply your leverage by a huge factor.
Aug 25, 2014 | Craftsman Garden
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
Changed cutting blade now blade will not stay stable in position to cut
did you get the cutter release knob back in the right place or position?
is the horseshaped bracket damaged in any way?
Mar 07, 2012 | White Sewing Superlock 1934D Mechanical...
Pull cord stuck
First. Remove the spark plug and see if any oil runs out.
Second, If the cylinder isnt flooded with fuel or oil. Make sure your blade brake is releasing properly.
Third. Remove the pull starter cover and consider putting a very light spray of WD40 onto the spring housing from the underside and work it around.....the recoil spring may just be rusted solid and a little lube and maybe a tap or too with a rubber mallet might just break it free.
I have seen all three conditions turn an otherwise working mower into something that wouldnt budge.
Good luck and be careful. Dont pull out the recoil spring as it under tension and could spring out and bite you or at least make a mess.
Jul 15, 2010 | Poulan "Poulan" Push Mower
How do I install the spring after changing the blade on the Makita 10 miter saw
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Jan 16, 2010 | Makita 10" Miter Saw LS1030N
Oster Power Pro Cordless Clippers I took the blade off, sm. long black plastic piece fell off. Wanted to change blade to ceramic. Can't get it back together don't know where black piece goes. Don't know...
The plastic piece is a blade guide and has a slot down the length of it which the spring locates into. Simply slide the replacement ceramic cutter under the spring
Sep 29, 2009 | Oster 76076-010 Hair Trimmer
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
