Question about Performance Designed Products Afterglow AX.1 Controller for Xbox 360 - Red " for 2010"
Why won't my afterglow controller function properly?
I recently went on a trip and purchased an afterglow AX.1 360 controller. I expected it to work properly. Unfortunately that was not the case. I arrive home and plug it in to the USB port on the front of my 360 slim. The controller lights up, but no activity occurs. The console doesn't recognize the controller, and vice versa. Not activity on the home button at all. I then try the same with my PC, to no avail. I have tried unplugging and replugging, disconnecting it at the cord break, and nothing works. If anyone can help, I'd appreciate it.
How do I get my PS3 afterglow controller with a chargeable battery installed to connect to my PS3 system. (afterglow controlder does not take AA batteries).
Afterglow AP 2 has a flat nickle battery
upgrade your controller
i take it yours is not a wireless
PS3 wireless afterglow controller uses aa rechargable
Mar 31, 2017 | HOW Video Game Consoles & Games
Need working mac drivers
not sure its possible. tattiebogle will help assign the buttons. check under about this mac and locate the controller under the USB setting. if it is listed it is recognized. I set up a similar controller on 10.8.4
Feb 14, 2014 | Microsoft Pl-3602 controller
My mic wont work with my afterglow controller
My afterglow controller wont work at all with my headset. It works perfectly fine with my other controller though. It is plugged in but says it isn't.
Mar 10, 2013 | Video Game Consoles & Games
Afterglow Headset won't turn on.
The battery is shot. These aftermarkets sit on the shelves for a long time, probably because they aren't made very well, and tend to break not long after purchase.
Jan 02, 2013 | PDP PS3 - Bluetooth - Afterglow AP.3...
My afterglow ax-1 xbox 360 controller won't stop vibrating when plugged in
Did you try plugging it in to another USB port? This sounds like a problem with the USB cable of your controller or the USB port on your PC. Try bending the cable near the plug etc. and see if it makes any difference. If not you'll be better off buying a new controller unless its still under warranty.
Nov 15, 2012 | PDP Afterglow AX1 Controller for Xbox 360
How to sync afterglow ax.4 headset with xbox 360
how do tou fix the after glow ax.4.the problem whith it is that my freinds can hear me but i have to un plug it to hear them
Aug 03, 2012 | Microsoft Xbox 360 Afterglow Ax.4 red...
My new afterglow controller won't sync but turns on, it is wired.
If by not syncing you mean it flashes the whole ring when you plug the controller in the USB and won't identify? If so I think the problem may be that you have other USB devices plugged in at the same time. Unplug all the USB and plug the controller in by itself. I've had issues with this for awhile myself. I had a bluetooth and another wireless kb/mouse. So I unplugged everything tried it by itself and it seems to identify perfectly.
Conclusion: Unplug all the USB devices and plug the Afterglow 360 controller by itself and that should solve the problem. =)
Dec 01, 2010 | Microsoft Xbox 360 Controller
2004 impala a/c blower not working
No it can not.
You have a couple of actuators that have gone out. The driver temp control. And the air inlet actuator.
And I don't fallow your statment of "my a/c blower went completely out. I tested the blower and it works fine".
If the blower went out, then what do you mean it works fine? Are you talking about air delivery or it just quits blowing all together?
Jul 01, 2009 | 2005 Chevrolet Impala
Cannot load the film
Check the battery. Sounds like your camera doesn't have enough power to operate the film advance function.
Apr 10, 2017 | Contax AX 35mm SLR Camera
Performance Designed Products Afterglow AX.1 Controller for Xbox 360 - Red " for 2010" Logo
292 people viewed this question
Top Performance Designed Products Video Game Consoles & Games Experts
James Wishart
Are you a Performance Designed Products Video Game Console and Game Expert? Answer questions, earn points and help others
