Question about In Microwave Ovens
I am in need of a Assy- GI T, P/N AP4248036 for the above referenced Microwave.
    Top Expert:
  • In Master
  • 51,548 Answers
Sorry I see no make or model listed here
Posted on Aug 11, 2015
Can you help me to get Hinano Microwave Combi Grill manual?
I searched and did not find a website for your product. I suggest the following clarifications and also a follow up suggestion to find the manual.
1, I suggest you post the model number or part number with your request.
2. Is it Combi or Combo?
3. Is Hinano the brand and if so, do they have a website? It seems Hinano is a term referencing Tahiti and there are lots of hits for clothing and apparel but nothing for appliances.
Follow up suggestion:
If you find the manufacturer's website, go into google and type:
site:hinano.com Hinano microwave combi grill manual
That will search only that specific website (the one I hope you find to put in and not the official beer of Tahiti site listed above...) and google does a much better search than built in search engines on specific sites. Good luck!
Jan 15, 2018 | Microwave Ovens
Samsung microwave oven model SHM 9187 st error code 5e
This model of microwave SHM9187 has a ribbon cable on the right hand side where the control assembly fits on the frame that picks up a signal from the frame that causes erroneous signals to be sent along one of the wires. It overloads the CPU and the result is a "SE" code and the machine shuts down. You need to put electrical tape over the entire surface of that ribbon cable in order to sufficiently insolate the cable. The repair is simple. Undo the two screws on top of the machine above the door. Pop the vent assembly to the left about an inch. Wiggle it off. Next there is one screw on the control assy at the top edge. Take it off. Pop the assy from the bottom and push up about a half inch. Lift top of assy away and rotate out. The ribbon cable in on the right hand side. You should unplug the microwave. When you reverse assemble everything and plug in the microwave, you are back to normal operation. Do the clock set and be happy.
Aug 16, 2014 | Microwave Ovens
I have a Sharp R-1870 Convection Microwave in my 2004 Holiday Rambler. I need to remove it to change out the motor and switch in the damper assy. How do I remove the microwave so I can do this? I&#
It's usually just the switch, and also be sure the damper door is not bent or blocked. We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
If you have other questions, please feel free to contact me directly (see below).
.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 26, 2017 | Sharp R-930AK Convection/Microwave Oven
I need a new motor for the turntable drive to replace the one which has died. ref numbers are: MN73SSTT3 RMOTDA267WRZ1 240V AC 2.5/3 rpm Manufacturer is I think DONG SUNG
Our Sharp R899 microwave also uses one of these. After much cross referencing I found that a FMOTDA057WRK0 would work. Purchased from Kitchenware Online and all working fine.
Sep 21, 2010 | Sharp R-510HW Microwave Oven
I need to install this range in a new kitchen and need to know the electical specs of the supply power
I don't see what range you're referencing. I see a title of microwave ovens. But, in any event, here's circuit requirement for each.
If it's a cooktop range: 220 volt 30 amp dedicated circuit
If it's a microwave: 110 volt 15 amp dedicated circuit
Charlie
Aug 22, 2009 | Microwave Ovens
How to replace the whole door unit
This should be a fairly simple procedure. To replace most microwave oven doors, all you have to do is open the door as wide as it will open and then lift straight up. The door will come off the hinge mounting pins and lift off. Install the new door by holding it in the open position and aligning it properly on the hinge pins. NOTE: On some models, you may have to remove the upper trim above the door. I hope this helps you. Let me know if you have further questions.
Jan 03, 2009 | Maytag MMV5000 Microwave Oven
Power level
Hi cindeet,
I don't have this particular model, but have experience with other GE stoves & ovens. Looking at the control panel for an Advantium 120 at the link below,
http://www.geappliances.com/products/introductions/advantium/downloads/advantium_brochure.pdf
I'd start by pressing the "Power/Temp" button, and then turn the knob to select which power level.
There is also a Help menu shown (upper left corner of the photo I'm looking at - page 4 of the PDF document referenced above.
Let me know how this works for you - thanks in-advance.
Jon
Dec 23, 2008 | GE Advantium 120 Convection/Microwave Oven
Removing Microwave
I just got my Whirlpool MH7100 off the wall. It was a bit of a hassle. I could not find a proper manual online at Whirlpool, but I guess since my unit was manufactured in 1993, who can blame them? Was the Internet even around in 1993?
There were 2 obvious bolts to remove above the microwave, these were found by opening the cabinet above. The next step was the hard one. Even after these were removed, the microwave would not lean forward so that it could be removed from the rear brackets. To get it to lean forward, I had to partially remove and partially break (i think) the vent for the exhaust fan. This revealed what looked like a very large screw with a regular head, one on each side. Once I unscrewed both of these, I was able to lean it forward and get it off the rear brackets.
Nov 25, 2007 | Microwave Ovens
Microwave Ovens Logo
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
