Question about Sewing Machines
Bobbin case wont stay in place when I sew - Sewing Machines
  • Sewing Machines Master
  • 9,490 Answers
Most bobbin cases have a latch that must be released to remove or install in the machine. Be sure to hold the latch open while you insert the bobbin case into the machine. Rotate the bobbin case slightly until it feels seated. Then release the latch. If the bobbin case is not latched in place, it will continue to fall out whenever you begin to sew.
Posted on Apr 02, 2015
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
First make sure you have the proper bobbin case for the machine you are using. (In case you have multiples or just bought the machine used) If this machine is new to you make sure you understand how to insert the bobbin case and lock it into place. Most have a spring latch you pull back, push the bobbin case on, rotate it to its proper position, Feel it push on even a little further when seated properly, then release the locking latch. Also check that something on the bobbin spinal/post is not obstructing the bobbin case from being fully pushed on. Or that the tip of the spinal/post is not damaged or broke off. It could be the bobbin case itself. Check for an obstruction. Also the latch on the bobbin case is normally spring loaded to lock it in place. Perhaps that spring is broken, damaged, or jammed? If all else fails you may have to replace your bobbin case with a new one, that is proper for the machine. If a new bobbin case doesn't work I would suspect the spinal/post and take it to a qualified service center for repair.
  • 35 Answers
You're not pushing the bobbin case into its furthest location. The hook at the top of the bobbin case has to be seated in one position only. There is an opening usually at the top of the receptacle where the hook is destined to lie and the hook must be aligned inside it.
Look with your eyes inside your machine into the place where the bobbin case resides and you will see clearly where the hook must be aligned.
Posted on Apr 01, 2015
The bobbin won't stay in the case. How might I fix it?
The bobbin case needs to be "latched" into place. Bobbin cases have a spring-loaded latch that needs to be open when the bobbin case is inserted, but when it is seated, the latch is released, thus locking it in place.
How to Set Up Sewing Machine
Inserting the Janome Front Loading Bobbin Case
Apr 18, 2016 | Sewing Machines
The bobbin won't stay in place
Your bobbin is too short. The correct bobbin must be even with the bobbin case. If it is the bobbin case that is moving around then you must adjust the inner rotary hook bracket assy. It must allow the thread to move between the corner (near screw) and the bobbin casing. Rotate the hand wheel towards you to make sure the thread fits between the corner and the casing. Make it as tight as possible without a snag taking place.
Feb 14, 2015 | Brother SE400 Computerized Sewing and...
Why wont my singer futura xl-400 bobbin case stay in place and keeps getting jammed
Hi, I just want to make sure. Do you put the bobbin under the little hook and then pull it up the case?
Jun 06, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
The hook race wont stay in place in my babylock Grace
Make sure brace that holds hook is locked, bobbin is pushed in til you hear it click and hand turn machine and if you hear it hit any metal, machine timing is out, let me know...thanks
Feb 28, 2014 | Sewing Machines
the bobbin case may need to be replaced. it wouldn't hurt to have the machine serviced to make sure the hook & hook race are ok
Apr 19, 2012 | Janome Sewing Machines
I cannot ge the bobbin case to stay in for my
unscrew the black plate that holds the bobbin case in place and move it over (to the left) ust a tiny bit. It still needs wiggle room, but moving that plate should help it stay in better.
Jan 10, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin Case Comes Loose When Sewing
The plastic drop-in bobbin case, is the worst I have ever seen. It is not staying in place. In front of the case, on the right there is a tiny, rectangle spring. It is the only thing I can find that keeps it in place. It is attached with a tiny screw and can be moved forward.
Sep 05, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer model 2732
It is either inserted incorrectly or the bobbin case needs replacing. Check the bobbin case by running finger tip around the outside of case, if rough spot needs replace. There is a ltch that is spring loaded you must hold back with small bladed screwdriver while inserting case for proper placement
Oct 25, 2007 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
224 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
