Question about Gateway One Hd Zx4931-31e 21.5" All-in-one Intel Core Duo E5800 Cpu 3.2ghz
My PC Desktop zx4931 starts to power up but then nothing, any ideas?
It usually only happens when it's moved
    Top Expert:
  • Gateway Master
  • 8,247 Answers
Sounds like a lose wire some were.check mains lead,or what ever you are using to power it up.
somthing is lose some were.
Posted on Apr 01, 2015
Gateway 5472 won't power up
You must register some sounds and usual noise from the case. If you consider that power supply works, try to unplug all unnesessary parts, and remain with CPU+Graphics+Memory. You are now closer to eliminate the current problem.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Apr 13, 2014 | Gateway GM5472 PC Desktop
I have a gateway ZX4931 computer with a built in webcam but I can not figure out how to use it.
is this a laptop or in a monitor connected to the tower of a desktop?
the webcams usually are located in the Control Panel of the Start button box. in control panel look for hardware devices, cameras, etc and click on that choice. it should list your webcam. it may be in the Programs list of the Start button(All Programs). It will be listed by the model number or manufacturer name. click on it to run the program if it is found. read the instructions or 'read me' file if listed under your webcam listing
Oct 13, 2012 | Gateway Computers & Internet
My Dell XPS 420 appears to boot up fine. The mouse moves OK, all my icons appear on my desktop as usual. When I try to click on anything nothing happens. When I try to use the keyboard buttons, eg....
Just a thought: Unplug the KB and mouse, wait a few seconds, then reinsert them. That's with the computer running. They are USB mouse and KB, right?
Please click the Comment button to reply.
Mar 03, 2018 | Dell XPS 420 PC Desktop
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I recently moved and when i hooked all of it back
open it up check all the connections memory and add in cards for security.
connect it and try again. Sometimes the bios battery can cause wierd problems, they are usually a 2032 battery on the motherboard. replace it if it's suspect. I would then look at the power supply. Big heavy capitors don't like being dropped, (neither do hard drives for that matter).
Jan 10, 2010 | Dell Dimension 8200 PC Desktop
Optiplex G620 has "munged" BIOS Admin password. Children plaed and saved. Any idea how to clear it ?
Hi there.
Try clearing the cmos fdbf23f.jpg. move the plastic jumper the alternative position, power the pc up (Nothing will happen if you have it correct, then put it back in its original position and try to boot the machine again, password should be removed.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Dell OptiPlex GX620 PC Desktop
Desktop Will Not Turn On
shut the tower off or unplug it form the back for a few minutes
plug in back in and then try to turn it on
you may have a power supply failure
let me know what happens
Jan 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Gateway One Hd Zx4931-31e 21.5" All-in-one Intel Core Duo E5800 Cpu 3.2ghz Logo
285 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
