Question about Sewing Machines
How to oil machine
Where are the places to put the oil. Bought 40 years ago. Very good machine. Cleaned out lint yesterday and feeder foot is working. Been stored. runs loud - however, I think it always did some. Don't want to damage by running if it needs oiling.
  • 3,957 Answers
Https://www.youtube.com/watch?v=4AYV3hbqF4U
Posted on Apr 01, 2015
  • Sewing Machines Master
  • 9,583 Answers
Not knowing the machine's make and model, it is difficult to comment. However, since the machine is 40 years old, it is more than likely a mechanical model which would require regular cleaning and oiling. Some of the older machines actually have oil holes in both the upper and lower (bobbin area) mechanisms. Be sure to use a good quality sewing machine oil, preferably not 3-in-1, WD-40, cooking oil, or the cheap generic sewing machine oil from the fabric department. Place only 1-2 drops of oil in each spot as too much oil is not good either. Then gently hand rotate the handwheel (toward you) to loosen things and get the oil distributed, Then trying running it slowly. (You should notice it running a lot quieter and smoother.) If things still seem a bit sticky, you can direct heated air from a hand-held hair dryer directly into the internal mechanism and see if that helps. You may have to repeat the oil and hair-dryer several times to get it going like it should.
Once you get it running nicely, you should clean and oil regularly--a good schedule is every time you empty a bobbin, every 8 hours of constant sewing, or every 6 months if it is not in use.
Posted on Apr 02, 2015
  • 35 Answers
Any place inside the machine where metal touches metal must be oiled with sewing machine oil. To get at the inner workings of the machine you will have to undo the bolts and screws that form its protective cover. Usually the top and left side of the machine will open quite easily. Then, removing the bobbin case you can get at some of the lower parts of the machine. Just keep turning the balance wheel to see which parts move and come together metal on metal when the machine is working.
After oiling and putting machine back together, run machine to give oil a chance to lubricate. The sound of a machine that is well taken care of is a very silent hum. Don't forget to put a strip of flannel fabric thru your machine to absorb any excess oil before starting your next project.
Testimonial: "I really do appreciate your suggestions. I did include the make of my machine. seems that info didn't get included. Viking Husqvarna 64 30."
Machine seems to be set up correctly but won't stitch. What do I need to do?
If, as you have noted, this is a mechanical machine, my suspicion is that it has not been cleaned and oiled recently and possibly the old oil has solidified preventing the parts from moving.
Here is a web site that may be helpful:
Janome Domestic Sewing Machine Maintenance
You may not need to go to the extent of removing parts and soaking them in cleaner, but certainly cleaning the dust & lint and then oiling with a fresh good quality sewing machine oil may be the ticket to your resolution.
Nov 22, 2015 | Janome Sewist 525S Mechanical Sewing...
Wheel on right side that controls the needle up and down is very tight. Hard to turn.
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil, liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer, other than a customer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. It is probably best to avoid oiling the metal cams. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
To find a manual:
Search the internet for "Kenmore 158.12511 Manual" You'll probably find a downloadable pdf manual (or at least one similar to your machine). Be very CAREFUL that they are not scam web sites (one wanted me to upgrade Acrobat when I just did it a couple days ago!) Here's one for $5.95-- http://www.sewconsult.com/kenmore/158%20manuals/kenmore_158_source_manuals.htm
or one for $4.99-- http://manualsoncd.com/product/kenmore-model-158-1212-1341-series-sewing-instruction-manual/
Here's one currently on eBay for $8.94--
http://www.ebay.com/itm/Sewing-Machine-Manual-Sears-Kenmore-1251-158-12510-and-158-12511-on-cd-/281847997472?hash=item419f732420:g:czAAAMXQPatTJ4FF
On the other hand, if you can find a manual from Sears, that is probably the most reliable (unless you can find a used manual on eBay, Etsy...) $15 isn't such a bad price if it helps you keep your machine running and reduces your frustration. You might also check Yahoo Groups for a Kenmore Users Group. Frequently, Group members will post those documents in the Group files or someone might have one that they no longer want.
Oct 31, 2015 | Sewing Machines
How do I fix the frozen presser foot take up lever?
Your machine most likely needs a good cleaning and oiling. The old oil has dried and turned to adhesive. You may want to bite the bullet and take it to a repair shop--probably around $100. If not, a lot of patience, elbow grease, and good quality oil will frequently work.
Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not connected or work with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual). Then hand-rotate the handwheel slowly and while watching where things move, place a couple drops every place where metal rubs against metal. Don't forget the bobbin area as it is very important. The shuttle race should get a drop of oil every 8 hours of sewing. But DO NOT oil plastic gears, cams, leather or rubber belts/wheels. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Since your problem emanates from the presser foot lever, oil around that. Don't forget the take up lever, look for the oil ports on it. There are usually at least 3 or more that require oil. If there are selector levers/dials, move those too and oil where parts move as well.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. (Tri-Flow does evaporate quickly, so using regular sewing machine will last longer.) Be sure to frequently use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in use.
Oct 20, 2015 | Sewing Machines
It was working , now it seems to be frozen. the needle part wont move
probably out of time and needs to go to the repair shop .
Aug 25, 2015 | Sewing Machines
Why won't Bernina Record 830 Foot Pedal won't move the needle?
could be something wrong with the foot pedal or could be a problem with a connection inside the machine.
Jul 27, 2014 | Bernina Sewing Machines
Good Day, I have a yamata fy920. I bought it more than a year ago and the presser foot is not working. Any help on how I get this fixed would be more than appreciated. Thanks in advance
Do you mean the foot control or the presser foot on the machine? if it is the latter then it may need a drop of fine oil such as WD40 on top of the pressser bar overnight, if it is the foot control check the pins that go into the machine to make sure one has not been pressed in.
Aug 07, 2011 | Yamata FY920
I have a singer touch tronic 2001sewing machine. I put the material to be sewed down, put down the foot and when I tried to sew, after a few stiches, it pulled the materal down and locked up. I pulled...
What type of material are your trying to sew? If it is stretchy, or thin put some gift wrap tissue paper under it to stabilize it. Also, adjust your tension to about 2 or 3. Now check your needle, put a fresh one in, maybe a 9 or 11. Do not use old thread, either because it breaks easy. Try this, I hope that it works for you. You can buy stabilizer, pellon but tissue paper is what we used years ago, sometimes even computer paper. Good luck.
Nov 10, 2010 | Singer Sewing Machines
My huskystar is sewing too slow. What can I do to speed it up? I have cleaned all the lint from bobbin area. The longer I sew the slower it goes.
it sounds like you might be in need of a good oiling you should use a good sewing machine oil not wd 40 or three in one oil. place a drop or two on the needle bar and the some on the needle bar crank
Aug 27, 2010 | Husqvarna Sewing Machines
My very old Elna Super foot pedal does not always start the machine. When I help it along with the wheel it might start going and then maybe not. Is it the motor or the foot peddle that is bad? Can it...
this sounds like the internal clutch drive is worn, it probably is not the foot pedal at all. It may be possible to repair it if you can track down an Elna serviceman. My Air Electronic SU got worn internally and my serviceman was able to repair it once for me.
Oct 28, 2009 | Elna 2007 Mechanical Sewing Machine
Kenmore Sewing Machine 16221 will not feed
Check for lint buildup between the feeddog teeth, will look like felt pads.....remove it !.........this little housekeeping should be done regularly......also ensure the correct stitch length is selected, not set at zero (OK, unlikely, but can happen !!)
Apr 23, 2008 | Sewing Machines
Sewing Machines Logo
62 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
