Question about Rascal 600 T Electric Scooter w Seat Lift - Used Mobility Scooters
Can you remove the reverse beep
I have looked and there are many different wires I do not know what one to remove
  • 3,960 Answers
Best way is to locate the beeper. There should be two wires coming from it. You can clip the wire and insulate the cut end. Best to cut the red wire if one is there, as it will be the power lead. If you sell the unit later, you can restore the beeper.
Posted on Apr 01, 2015
    Top Expert:
  • 10,875 Answers
Disconnect it
On my 2002 mercy grand marqius when u put in reverse the trunk pop open
Your reverse light wires are probably
rubbed thru and touching the wire
that activates the trunk release. remove
the reverse light bulbs and see if it does it again, or remove the fuse for the trunk release. Also have someone look at the
reverse lights while your pushing
the trunk button on the drivers door.
If yhey come on then you know the circuit
is shorting to power
Nov 02, 2016 | Cars & Trucks
I have a 2012 Hyundai ix35& have fitted a towbar wiring loom.
take it to an accredited auto electrician to have the reverse sensor disconnected when the trailer is connected as the sensors are seeing the trailer when reversing and that is why they are beeping
Feb 17, 2016 | Hyundai Cars & Trucks
How do you disconnect a reverse beeping signal on a 2006 Toyota Sequoia?
I have found the beeper wired into the reverse lights and if you just find the beeper and cut off the wire and cap it you should be fine and no more beep.
May 05, 2014 | Toyota Sequoia Cars & Trucks
How do I turn off the beeping that happens when i use my scooter in reverse?
Hi, it 's normally a small buzzer locate near the controller , in bedded within the wiring loom, look for the circular shape within the plastic selves...
Regards
Rob
www.gewizrepairs.co.uk
Apr 26, 2014 | Shoprider Scootie Jr
Disable reverse beep on pride mobility scooter
I cut reversing feed wire to the beeper while still maintaining the horn beep. You have to know what you are doing though as on scooters they switch the earth/neutral rather than the live as in mains electrics.
There is a better way though. I believe a scooter shop can disable the reversing beep via the scooters drive computer. They just plug their laptop in and do some jiggery pokery.
Dec 09, 2013 | Cars & Trucks
When I try to boot my EVGA P55V micro mother board all it just goes beep beep beep, repeatedly I'm using a EVGA e-GeoForce 9600 GT card nothing apears on my screen it doesnt even look like its booting, the...
that beep (1 long and 2 short) indicated your ram has problem, from your suggestion i can know that your ram was died, change your ram with new one it will solve your problem
Feb 25, 2011 | Evga P55V 120LFE651TR LGA 1156 Intel P55...
Does not ignite error code flashes 6 times
Look on the reverse side of the removable front panel of the Carrier. Each model will have a wiring diagram and a diagnostic chart to help you pin point the issue. Without knowing the model number the error code means something different for each model.
Nov 20, 2010 | Carrier Heating & Cooling
Beeping when backing up
hi pam from the uk ! the reverse signal/beep can be disconnected however there are different methods of how the beep is operated ? in uk some cars have the reverse light bulbs that are also a beep sounder when reverse engaged ? orthe sounder may be a seperate sounder unit at the rear located either in boot? or behind rear fender? or as you mention beep sounds inside boot area?? the sounder may be hidden behind one of the side panels in boot? if you put ignition on and select reverse then try finding beep location? if/when you find it? just disconnect wirefrom sounder and make sure reverse light/s still remain on tape up the wire disconnected out of way? if it is the bulbs that bleep? you will have to remove and fit an ordinary type bulb usually a flasher/ indicator bulb? hope this is of help and inspires you to diy ? best wishes
Nov 09, 2008 | 2007 Toyota Prius
Faulty door which keeps beeping
The door could be closed physically but the not electricity because a defective lid switch that should be replaced. Good luck!
Nov 01, 2006 | Hotpoint WMA76 Front Load Washer
Beep sounds and their meaning
Hi All PC do what is called a POST a Power On Self Test and emit different beeps according to the make and model of the BIOS loaded. You can check out what they mean for different BIOSes here http://www.xmission.com/~comphope/beep.htm. This site lists the different post codes etc by the different bioses. So you will need to know what BIOS your PC is running just check the black screen at starup before any windows info comes up and look for something like AMIBIOS or AWARD etc, you can pause the screen so that you can read it more easily by pressing the pause button on your keyboard, this is normally the last key on the top row on the right. Hope that helps
Sep 04, 2006 | MSI 915P Neo2 Platinum Motherboard
Rascal 600 T Electric Scooter w Seat Lift - Used Mobility Scooters Logo
198 people viewed this question
Top Rascal Health & Beauty Experts
Robin Hill
Robin Hill
ka4iup
ka4iup
Scooter Doctor
Scooter Doctor
Are you a Rascal Health and Beauty Expert? Answer questions, earn points and help others
