Question about Honda EU3000iS Inverter Generator
Honda 3000is runs great on eco but hesitates and either stops the load source or stops running itself when under load.
  • 21 Answers
Sounds like the throttle control motor is not adjusting the engine speed to compensate for the load. Does the generator rev up to full speed if you turn OFF eco with NO load?
Funny thing, I have one on my workbench that is doing pretty much the same thing. Runs on eco, revs up with eco off with no load, coughs, sputters and dies with a load in either mode. I will update with what I find when I figure it out in the next week or so. Have a new carb on order.
I swapped the carb and it made no difference. Still backfiring (rather dramatically) and won't stay running. I see on some other posts that Valve lash will cause this. It makes total sense as the exhaust valve gap actually tightens as the engine wears which would keep the exhaust valve slightly open when it ain't supposed to be allowing raw fuel to enter the muffler.
With this one I can believe it as it has a ton of hours on it and I know they have never been adjusted.
I will try to get a chance to do it over the weekend and update this post when I do.
Posted on Apr 01, 2015
TLFederline4
  • 12 Answers
SOURCE: sputtering and hesitating
Try replacing the PCV valve, and spray the carb, or throttlebody, with a good carb and choke cleaner.
Posted on Apr 10, 2009
Robert R
  • 7 Answers
SOURCE: 2004 Ford F-350 6.0 Turbo Diesel - Severe Hesitation at Take Off
Some of these engines have a place to drain water out of the fuel system.. Some fords actually have a stick under the hood that you push or pull That opens a valve on a water collection bowl. It's not labeled usually. It might state where it is in the owners manual under fuel water drainage or something similar.. if that bowl is full it will cause hesitation... If it gets over full it will cause runability problems. Another possibility since you said it's black smoke is one of your injectors is sticking at low rpms and squirting raw fuel into the cylinder till the rpms get up enough to burn that fuel off completely then then the injector works a little better.... Do you notice any missing... Feel something under the hood like the air cleaner housing and make sure the vibration is constant and doesn't have a small sudden shake and the n smoothe... And then a small sudden shake again.
If it does have this shake you can trouble shoot which injectors by with the engine running loosening an injector line and seeing if the engine runs worse or not.. If it runs worse tighten it up and move to the next line till you unscrew one and feel and hear no difference... When you find that one that's the injector with the problem.
Posted on Apr 22, 2009
SOURCE: Car stumbles,hesitates,loses power on Hwy, randomly
Did you check earth connection of electric system?
Posted on May 10, 2009
  • 5 Answers
SOURCE: Ford F-350 6.0 Turbo Diesel - Severe Hesitation at Take Off
sometimes when the motors under enought pressure it will black smoke..so mabe the transmission is hanging up or something in first gear,,,i can rev my truck up all day and it wont black smoke when these a sever load o it and i hammer down it putts a bind on the motor and fuel is steadly being pump into the motor causing unburn fuel witch is black smoke..so maybe you want to go check the transmission or the fuel PUMP not the filters
Posted on May 17, 2009
SOURCE: hesitation under load ,creating a misfire code that clears in three drive cycles
Egr valve port hole have to remove the intake to clean but that's my problem rite now on a 4.3 vortec the port hole gets cloged with carben not slowing it to work properly.
Posted on Jun 07, 2011
Why can't i run my a/c with honda 3000is generator
This generator will run an a/c unit up to 13500 btus and is good for 2800 watts. This is a small generator, the nameplate rating numbers need to jive before overloading the energy supply.
Jun 03, 2017 | Honda Electrical Supplies
13,500 a/c blows circuit and won't run off our honda 3000is generator
will it blow any circuit? if so, the a/c has an electric problem. will the a/c run when plugged into a
service power supply?
The generator will not hold the load.
Confirm that the ECO-Throttle Switch is in the off position. When in the ECO mode the unit goes into an idle condition and when detecting a load will spin up to operate the load.
In the off position the unit will remain in the ready for load speed taking the initial load with less hesitation.
If this does not solve the problem it is likely the carburetor has some old fuel residue. This residue restricts the fuel flowing through the carburetor. Suggest using a fuel additive carburetor cleaner added to fresh fuel and allow the unit to run under load for an extended period. These gas treatment products are readily available at any auto parts store.
These carburetors have no adjustment for fuel mix and after trying fresh fuel and cleaning the fuel system with additive the only remaining choice would be cleaning or replacing the carburetor.
Nov 21, 2015 | I Power In Box Honda Eu1000i Power...
What causes hesitation in a 2007 honda accord v6
Could be many things. I assume no codes are set, so bad TPS possible, bad cat converter or muffler, even coolant temp sensor or O2 sensor starting to fail. Tune up items also.
Feb 23, 2015 | 2007 Honda Accord Sedan
Honda EU 3000is only runs on half choke
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
May 04, 2013 | Honda EU3000iS Inverter Generator
Have a Honda EU6500is generator with 410 hours. I live off grid and run the gen 2-3 hours daily. The generator rpm surges under load on eco throttle and surges under load AND without load when the eco is...
i have the same problem with a new one ,take a peace of paper and cover the battery cover air inlet when it's running ,if your problem stops-it's the seal around the cover,a honda rep let the cat out of the bag,---jk
Sep 08, 2011 | Honda Electrical Supplies
94 Honda Accord LX hesitates when starting
temperature sensor for the auto choke
Nov 25, 2009 | 1994 Honda Accord
EU 3000is generator is running rough with Eco Throttle on
The air intake system on this unit is highly fine tuned. Make sure all covers including front battery cover, plenums, air intake system is properly installed and that any and all gaskets on doors and covers are not damaged.
Oct 01, 2009 | Honda 6370C - Parallel Power Kit For ...
Apr 22, 2009 | 1997 Ford F350 Crew Cab
Honda EU3000iS Inverter Generator Logo
484 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
