Question about storz SCB Electronic Endoflator 26430520 20 L Insufflator
Only some led litt but figures not light up - storz SCB Electronic Endoflator 26430520 20 L Insufflator
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
Most likely a display problem, driver I c, or the wiring between the two.
Posted on Jun 25, 2016
How do I change my motor mounts or figure out which one is broken for that matter?
put no the brake and put in gear.with litte gas in drive or rev
Aug 23, 2013 | 1999 Plymouth Breeze
How to change the batteries in Schwinn Tool Free LED light Set
You have to keep the black rubber, triangular button depressed while you slide it opposite way of the LED lights.
(Just face the LED lights side to your body,depress black rubber button and slide down)
Hope this helps!.
Feb 03, 2013 | Schwinn Tool Free LED light Set
Hi i have an experia ant the littli led light on the top stays on red all the time
Hi.
The little red light means your battery requires charging.
Plug in the charger and allow it to charge.
It should change colour to orange when it has over 15% charge in it and then turns green when it is 90% charged.
If it still stays red dispite being fully charged. Try removing the battery for a few seconds and then replace it again.
I hope this helps.
If your phone is fully charged and it still has a red light, then take it back to the shop you acquired it and get a replacement.
It means you have a hardware fault.
Mar 09, 2011 | Sony Ericsson XPERIA X10 Cell Phone
The screen went black the litte red lite blinks...
the light indicates an internal electronic fault with your set
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Apr 28, 2010 | Televison & Video
My acer netbbook wont come on the power light is litt
Mother board or memory module can be the problem. First remove the cmos battery and switch on, if its ok then reinstall the cmos battery and see.check with other memory module or if you have 2 modules one at a time. If problem persists, try heating the motherboard display chipset with a blower, if you are a hardware technician. This should be done by only a professional as u can damage the motherboard and other parts. Last resort is replace mother board.
Sep 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Led light
The light that used to stay on all the time is most likly the Power light(LED) The light that used to flash when you were using the computer is the  HddLED(Hard disk drive Light Emitting Diode) If you mixed them up it wil likly only light the wrong light.    I hope this helps.  If you wish to be sure you may be able to download the owners manual  the manufacture ?
Oct 02, 2008 | Gateway GT5220 PC Desktop
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Help?
in off pos litte button on front u adjust it or push in main thing set time as its in standby mode ok
Feb 10, 2008 | Panasonic CQ-DFX403U CD Player
storz SCB Electronic Endoflator 26430520 20 L Insufflator Logo
471 people viewed this question
Top storz Electronics - Others Experts
Are you a storz Electronics - Other Expert? Answer questions, earn points and help others
