Pls undertake some action yourself and open the unit and learn how it is put together. I' m answering 70% of my time , searching for manuals ans and stuff, cause people are to lazy....
Is it connected to a "PHONO" input or something not labeled explicitly for PHONO?
"PHONO" is the only designated connection on an audio device that is literal and exclusive.Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
Link below has Paragon EC7000 series timers and manuals EC7004/120 is 7-day programmable timer. Single channel 120Volt SPST NEMA1 indoor timer. Program up to 16 events per week http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting. It is impractical to write out those steps when they appear in manual. http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
Woods timers and manuals are shown on following link: Add a comment if your timer is not shown. Woods timers are sold under different numbers depending on who packaged timer and which outlet sold timer. Not every Woods timer has manual available on-line. http://waterheatertimer.org/Woods-timers-and-manuals.html
Timer shown is E1020 or E1010 This timer wires into a wall box Grasp time dial firmly and pull until it comes free from timer. Remove all silver ON trippers and brass OFF tripper using pencil or paper clip
Program the timer by inserting trippers The minimum set time for this timer is 1/2 hour OFF trippers should be spaced at least 2 hours apart from another OFF ON trippers should be spaced at least 2 hours apart from another ON
Push time dial back onto timer Current time lines up with time line located at top of timer dial
Next to the time line is the manual override. Use manual override to reverse the timer program, so if lights are OFF, manual override will turn them ON.
