Question about Miscellaneous
How do i install subwoofer n prologic wire
Full wire installation out put
  • 3 Answers
You have subwoofer out as an RCA cable, pls use that. Or if it is an passive sub you only can give it with front speakers. Pls connect coaxial or optical or Homi cable for full output />
Posted on Apr 23, 2015
How to assemble boss sub woofer,any?
If you have already bought the subwoofer, you will need to buy an enclosure for it. As well, you will need an amplifier and a compatible receiver for the amplifier.
Once you have all of these components, you will need to wire them all together. For this, you will need a pair of RCA cables to run from the receiver to your amplifier, a power wire to run from your amplifier to your battery, and wire running from your amplifier to your enclosure/subwoofer.
For a more in-depth tutorial on how to install your subwoofer, check here:
http://www.wikihow.com/Install-Subwoofers
Mar 01, 2011 | Boss R12 Riot Series Subwoofers (12 ;...
No sound out of speakers diagnostic button does not produce test tone,and right main speaker control flashes PROLOGIC. I have heard the motorboat sound coming from the subwoofer,but no sound now,green...
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
Dec 18, 2010 | Altec Lansing ADA 885 Computer Speakers
Install
go to crutchfield.com call them and get wire harnesses for them they carry all of them and have directions for install.
Apr 05, 2010 | Pioneer TS-G950M Coaxial Car Speaker
Wiring instruction for 1000 watt rms @1 ohm Installation for 1800 watt 'Outcast' 12inch subwoofer(s)
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
go here put in your specs you have your answer.:]
Oct 04, 2009 | BOSS AUDIO SYSTEMS OUTCAST LAC128D Car...
'04 Nissan Sentra S factory installed subwoofer wiring diagram
A FACTORY INSTALLED AMP/SUB WILL BE WIRED INTO THE VEHICLES FACTORY WIRING JUST AS ANY OTHER COMPONENT. YOU WOULD THINK THAT YOU WOULD FIND THICK POWER AND GROUND CABLES ALONG WITH RCA CONNECTIONS AS YOU FIND WITH MOST INSTALLS.NOT THE CASE HERE.YOU MUST FIND THE HARNESS THAT HAS THE POWER AND GROUND CONNECTIONS ALONG WITH THE INPUT WIRES FOR SOUND. YOU MUST OBTAIN A VEHICLE SPECIFIC WIRING DIAGRAM THAT HAS THE WIRING FOR THE SOUND SYSTEM PACKAGE THAT CAME WITH YOUR VEHICLE. YOU MUST THEN WIRE IN THE BLUE REMOTE TURN ON LEAD FROM YOUR UNIT TO TURN THE AMP AND SUB ON WITH YOUR RADIO AND NOT YOUR CAR BATTERY. YOU WILL ALSO NEED TO FEED SOUND TO THE AMP USING ONE OF THE REAR OUTPUTS FROM YOUR RADIO.
Sep 05, 2009 | Car Audio & Video
My panasonic SC-AK87 dolby prologic, surround mode and 5.1 chanel didn't work. Just radio fm can work/ Help me!
the out put is common to all channels, only that sounds are thickened or lighted by adding components like capacitors and resistors.
open your set and check for a dry joint on the channel which is not working
dont forget to check the cables, not having cuts
Apr 27, 2009 | Yamaha NS-A60X Main / Stereo Speaker
No Sound
try switching the prologic mode on in the audio setup menu also switch front spks to small in the speaker setup
Apr 11, 2009 | Audio Players & Recorders
What do i need to install a subwoofer
Here's what you need:
1) An enclosure for the 8" subwoofer.
2) 8" subwoofer.
3) Amplifier to power the sub.
4) Amp wiring kit.
Your Sony has two sets of preamp outputs so make sure that your wiring kit includes a set of RCA's.
Mar 24, 2009 | Sony Car Audio & Video
New (old) house with stuff installed when we got it
IF YOU HAVE THE SAME AMOUNT OF CABLES AS SPEAKERS HOOK THESE UP TO YOUR AMP THEN SUB TO SUB OUT PUT ON YOUR AMP WITH A SUB CABLE OR PHONO THAT REACHES FROM AMP TO SUB.SET AMP TO ALL CHANNEL STEREO OR MODE THAT SENDS STEREO TO ALL SPEAKERS,ALSO SET SPEAKER SIZE IN SETUP OF AMP TO SMALL AND SUB OUT PUT TO SUB ONLY.YOU SHOULD GET MUSIC AROUND THE HOUSE.IF SOUND IN SAY BEDROOM IS NOT AS LOUD AS BATHROOM USE THE TEST TONE TO LEVEL OUT EACH SPEAKER.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Sony STR-DE697 7.1 - Needs Dolby Prologic IIx
Hi Plasie, unfortunately you cannot upgrade this level of electronics easily, nor cheaply. Updating the whole rig is you only answer
regards
Graeme
Mar 21, 2008 | Sony STR-DE697 Receiver
Miscellaneous Logo
61 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
