Probably it is not a very good keyboard. Buy a better one. Genius keyboeasd are the best
Genius GX Gaming Keyboard with Backlit System and 2 USB Ports GX Gaming...
To install your keyboard or mouse:
To install the device driver from the Gateway System Restoration Kit:
The keyboard does not work
Make sure that the keyboard cable is plugged in correctly.Remove all extension cables and switchboxesTry a keyboard that you know works to make sure that the keyboard port works.Clean the keyboard by using an aerosol can of air with a narrow, straw-like extension to remove dust and lint trapped under the keys.Try a keyboard that you know works to make sure that the keyboard port works.Reinstall the keyboard device driver. For more information, see Installing the device driver.
A keyboard character keeps repeating
Make sure that nothing is resting on the keyboard.Make sure that a key is not stuck. Press each key to loosen a key that might be stuck, then restart your computer.
Liquid spilled in the keyboard
If you spill liquid on the keyboard, turn off your computer and turn the keyboard upside down. Let the liquid drain, then let the keyboard dry before trying to use it again. If the keyboard does not work after it dries, you may need to replace it.
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
or if this does not fix the problem
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
hope it helps
