Question about Konica Minolta Bizhub c203 Copier
Konica c203 do not power on
After plugin power cord to network copier won't start.
  • Konica Minolta Master
  • 6,359 Answers
Recommended that you get a technician out to look at that machine. Might have a problem with the machine power supply board, or the noise filters, and or control panel.
Posted on May 18, 2015
  • 15 Answers
SOURCE: Konica Minolta C450 status is offline.
Change the status to "Online". Sounds crazy, but most likely you print driver is set to enable "SNMP" on the port settings. Disbale this setting in the print driver, also set print Queue to "LPR" and name the LPR queue as "printer". Make sure there are no jobs int he queue when you change the port settings.
Posted on Jun 09, 2009
  • 51 Answers
SOURCE: lost ability to print on Konica Minolta copier
whot is the model
Posted on Sep 17, 2009
  • 165 Answers
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Posted on Apr 05, 2010
Bizhubman
  • 108 Answers
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Posted on May 22, 2010
  • 118 Answers
SOURCE: Hi, Our Konica Minolta printer
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
Posted on Oct 16, 2011
Please how can I clear the memory on my printer (Konica Minolta bizhub C203 coloured printer)
Go to service mode
utility-counter-stop-00-stop01
go to system 2/ or 1
select initialization.
select all data.
press start button
restart from main power.
Re-configure all network setting for printing/scanning
Nov 29, 2016 | Konica Minolta Bizhub c203 Copier
5 Touch [Network Settings] disappeared on Konica C203
have the copier firmware reflashed have tech do as the firmware is located on secure server
Sep 30, 2016 | Konica Minolta Bizhub C203
Konica minolta bizhub c203 blue data light blink copier not working
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Jan 24, 2016 | Konica Minolta Office Equipment & Supplies
Konica minolta c203 reboots after power up
power issue or the os has failed, have tech check it out
Jan 19, 2014 | Konica Minolta Bizhub c203 Copier
Hi, Our Konica Minolta printer c203 with reserved dynamic ip address in dhcp (windows server 2008 r2) won't print. Should I assign a static ip address? Kevin
Sep 20, 2011 | Konica Minolta Bizhub c203 Copier
Hi, I have a Bizhub C203 and the scanner does not seem to work since we lost our network yesterday. Network is now up and running but I don't know how to tell the scan function that!
hmmmm either your scan file was lost or changed to a new location or your email has changed or needs authentication... there are a bunch of different things that can make that happen, can you print to it??
Apr 14, 2011 | Konica Minolta Bizhub c203 Copier
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta Bizhub c203 printer will print from all computers in our network, but has stopped scanning
Apr 05, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta Bizhub c203 Copier Logo
52 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
