Question about Cuisinart CBK100 2lb Bread Maker
How to take off bottom plate from a cusinart cbk100 bread maker
The shaft is sticking, and possibly needs greasing
2 Suggested Answers
proartya8765
  • 581 Answers
SOURCE: Breadmaker kneader slips. Belt is fine.
here is the site to oder the part for your breadmaker
http://www.cuisinart.ca/cuisinart_parts_accessories.php?product_id=8&item_id=11&cat_id=24
Posted on Nov 28, 2009
What grease is used on the shaft seal on a HB B301 Hitachi bread maker?
It is food grade vegetable grease and is normally fitted within the bearing. If it is leaking, a new container is required as I wouldn't fancy eating grease and the seals have been damaged/worn out. Never use silicon or mineral based car grease. Not good to eat at all and poisonous in small quantities.
Feb 09, 2014 | Zojirushi BBCC-X20 Home Bakery Supreme...
Where is the ol coming from?
There is a rubber seal in the bottom of your pan that has failed. There is grease under that seal to keep the spindle that turns the paddle lubricated. If your breadmaker is still under warranty contact Cusinart to get help. If it is no longer under warranty then you could still probably order a new pan from them. If you just want to get rid of the darn thing you can always send it to me. At least that way it won't end up in a landfill. You can reach me at daryl441@msn.com
May 30, 2013 | Cuisinart CBK-200 Bread Maker
The paddle at the bottom doesnt turn
Bread my pan pops out
reach in with your fingers and bend the two little clips out a little until they grip your pan snugly. Start with 1/4 " and try that. If it doesn't feel snug go another 1/4 inch.... and so on....
Sep 22, 2011 | Cuisinart CBK100 Bread Machine
I have this machine for 4 years now and I was happy with The central shaft does not turn now and I lost all my stuff... It makes the noise like if it works, but nothing happen... and there is a...
Hi.. The "central shaft" could mean the motor shaft is not turning or the "central shaft" could be the paddle shaft in the bread pan is not turning. If it's the motor shaft then tighten or replace belt. Since you "lost all your stuff" it could be the sealed bearing in the bottom of the bread pan has broken. The paddle doesn't turn and is leaking. If this is the case the bread pan needs replacement. Hank
Jan 18, 2011 | Black & Decker B1561 Bread Maker
Black stuff is coming up from the center mixing part and getting into my bread. Is it grease? How can I get rid of it? Thanks for any advice. Leanne
Hi, Yes it is a form of grease. The sealed bearing that the paddle shaft fits through has failed and is leaking out the lubrication. You will need a new bread pan. (Sorry it took so long for you to get a reply). Hank
Nov 08, 2010 | Cuisinart CBK-200 Bread Maker
My frigerator is making ice but will not let it drop down in the bucket. I have replace the bucket but it will not work. It's also has water draining from it.
Remove the bucket and clear it completely out you will have to rotate the bar to clear out the crushed ice and snow I have had to run warm water through mine and then let it sit out to dry. Good luck its a pain
Hope this helps Lezette
May 26, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Nov 28, 2009 | Cuisinart CBK-200 Bread Maker
Lopsided 1.5 lb loaf
This sounds like a mixing problem. Put all the liquids in the bottom, then the dry, and finally the yeast on top so it mixes last.
After the first mixing, the dough should be a ball with nothing sticking to sides.
MEASURE ingredients carefully!
Verify that the paddle turns freely. If it doesn't, then dis-assemble the paddle and clean bearing and shaft. Lube with foodsafe grease before re-assembly.
Nov 14, 2009 | Kitchen Appliances - Others
Lubricant for bread maker pan mixer shaft
I just cleaned the shaft and put on Silicon. It seems to be working at top speed now. I almost threw the machine away, but itt makes wonderful bread.
Jan 05, 2009 | Kitchen Appliances - Others
Cuisinart CBK100 2lb Bread Maker Logo
50 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Irene Tulloch
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
